We are getting there!! It works beautifully for the first mxd. Then I get an unexpected error: ValueError: Layer: Unexpected error Database Platform: SQL Server. This is when I have the validate set to True. When I change it to False, It runs through all the mxds successfully but my links are broken except for the first one which works. Cheers!
First successful mxd data source:
Data Type: SDE Feature Class
Server: sql
Connection Properties: sql
Authentication Type: Operating system authentication
Database: C
Version: sde.DEFAULT
Description: Instance default version.
Feature Dataset: C.SDE.Base
Feature Class: C.SDE.parcel_pmbc
Feature Type: Simple
Geometry Type: Polygon
Coordinates have Z values: Yes
Coordinates have measures: No
Second mxd data source
Feature Class: parcel_pmbc
SERVER: sql
INSTANCE: sde:sqlserver:sql
DBCLIENT: sqlserver
DB_CONNECTION_PROPERTIES: sql
Database: C
IS_GEODATABASE: true
AUTHENTICATION_MODE: OSA
CONNPROP-REV: Rev1.0
VERSION: sde.DEFAULT
