Item usage not correctly getting requests
2818
03-28-2023 08:37 PM
Ian-Horn
I want to be able to query the number of item requests during a certain time period. If I use:
ap_hits = ap_item.usage(date_range = '6M, as_df = True)
 But if I uses date_range = '24', '7D', '30D', or '60D' it comes up as None
As you can see from the '6M' option, I do have requests in the last 7D.  Why can't I do get the requests with specific time dates less than 6 months?
ChristopherCounsell
MVP Frequent Contributor
BUG-000155249 has been fixed. Can confirm that returning as data frame now works expected
from arcgis.gis import GIS
gis = GIS("home")
# Replace 'item_id' with the actual ID of the item you want to retrieve
item_id = ''
# Get the item by ID
item = gis.content.get(item_id)
item_hits = item.usage(date_range= '7D', as_df = True)
print(item_hits)
ChristopherCounsell
BUG-000155249
You can get the usage if you don't return it as a data frame:
testDictionary = item.usage(date_range='30D',as_df=False)
 But then you have to combine them together. I made a spreadsheet from the dict. Another user sums it, example here:
https://community.esri.com/t5/arcgis-api-for-python-questions/the-usage-property-for-an-item-returns...
Ian-Horn
Thank you,  I will look into this.
ChristopherCounsell
gis = GIS("home")
item_id = ''
print(item_hits)
JoeGuziStarkCountyOH
Greetings,
I just upgraded my notebook runtime to ArcGIS Notebook Python 3 Standard - 9.0. Now when I run udf = Item.usage(date_range='6M', as_df=True), it appears to work, but I get  the following warning:
any ideas on how to resolve this, or is this a hope and pray the next update to the python api resolves this? Thank you for everything and have a delightful day.
Sincerely,
Joe Guzi
ChristopherCounsell
A quick search indicates that pandas is deprecating datetime. Generally suggests a future update will break it...
It's probably worth a new post and discussion as it's a separate question. This post was specific to a failure/bug which has since been fixed. New question specific to pandas/python/datetime might gather more attention.
