Issues with Python scripts after ArcGIS Pro update.
3541
05-16-2021 12:10 PM
DimitrisIoannidis
Hello all,
I was developing a number of stand-alone Python scripts last couple of days and were working perfectly.
Today, I updated the ArcGIS Pro to the new version (2.8.0) and the scripts do not work anymore. Whenever I try to execute them, I get the following message:
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 120, in <module>
import arcpy.sa
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sa\__init__.py", line 18, in <module>
from .Raster import Raster
ModuleNotFoundError: No module named 'arcpy.sa.Raster'
I navigated to the aforementioned path in order to find the Raster.py file but it was not there.
Could you, please, help me with this?
Thank you in advance.
DanPatterson
MVP Esteemed Contributor
C:\...YourInstallFolder...\Resources\ArcPy\arcpy\sa\Raster.py
it is there.
Did you do a clean install?  An install from the downloaded *.exe (or *.msi)?  Or did you update through Pro?
through python
import arcpy.sa.Raster as R
dir(R)
['RAT', ... snip
 'addDimension', 'appendSlices', 'bandCount', 'bandNames', 'bands', 'blockSize', 'catalogPath', 'compressionType', 'exportImage', 'extent',
...snip
 'setVariableAttributes', 'slices', 'spatialReference', 'standardDeviation',
 'uncompressedSize', 'variableNames', 'variables', 'width', 'write']
... sort of retired...
DimitrisIoannidis
Hi @DanPatterson  and thank you for your reply.
The Raster.py is not in the directory that you mentioned.
I didn't do a clean install and didn't use an exe file for the update.
The update was applied through the ArcGIS Pro GUI.
Any thoughts?
DanPatterson
Don't know.  I always do a clean install from the *.exe to get the *.msi and the *.cab, so I have a copy and don't need to re-download.
I always find clean installs save me the most time... a little house tidying is usually in order between versions.
ChelseaRozek
MVP Regular Contributor
I was curious if this was widespread, so I checked mine. I upgraded to 2.8 through the Pro GUI and I still see the Raster.py in my folder.
DimitrisIoannidis
I have downloaded the .exe file and applied a Repair Install.
I am good to go, now. Everything runs perfectly.
@DanPatterson @ChelseaRozek thank you so much for your inputs!
