Issues to work with Excel files with arcPy!!
4546
13
09-22-2015 08:05 AM
SaidAkif
Hi all
I tried to convert excel sheets to table. I did the folowing:
the problem that I got a message 000732 that imput table table .....\file.xlsx\'ATL...$' does not exist or not supported (makeTableView).
the list (Listxls) is well populated. Moreover, I tried the same work at home and it work fine. I really don't know what happen?
Any help please?
By the way, I hve lot of trouble to use this webside. I can't copy/paste anything. My interface is :
Thanks in advance
SaidAkif
Hi all
I realize just right now that in the message error, the name of the file contain 2 times the Excel file name which is i believe the source of the error.
I Tried all combinaison, but the error happen all the time
Any Idea
RebeccaStrauch__GISP
Said, In 10.2.2/10.3 I have been successful
arcpy.ExcelToTable_conversion(FileXLS, outFGDBtable)
But my process is a little different in that I'm also creating the Excel file from a .csv to start with, so only one tab.  But I would look more into that command to see if it would work
Excel To Table—Help | ArcGIS for Desktop
SaidAkif
Unfortunaitly, I work with 10.1 version
have you tried TableToTable?
ArcGIS Help 10.1
Syntax
TableToTable_conversion (in_rows, out_path, out_name, {where_clause}, {field_mapping}, {config_keyword})
SaidAkif
Hi
Thanks I used this TableToTable as you mention (the same way). but I still having the same error. As I mention before, the problem is the duplication of the Excel file name (...xlsx) in the valeur variable (please see my first message)
JamesCrandall
MVP Frequent Contributor
What are you expecting the output "table(s)" to be exactly?
I see you set an "outGDB" variable, but that is only pointing to the folder not an actual Geodatabase.
"tablename" is going to output what type of file exactly?  I don't see where you are specifying any file extension anywhere.  The source doc says you would be just creating INFO table outputs without any extensions supplied.
http://resources.arcgis.com/EN/HELP/MAIN/10.1/index.html#//001200000027000000
SaidAkif
Hi all,
Sorry I use the image link because I have trouble to copy/paste in this website. So here is the code and th message erro. You can see that the priblem is in the input table.
Thanks for your help
WesMiller
Regular Contributor III
MakeTableView_management (in_table, out_view, {where_clause}, {workspace}, {field_info})
arcpy.MakeTableView_management(valeur,os.path.join(outGDB,tableName,".dbf"))
SaidAkif
Hi
I try this but the same Error. The problem is in the duplication Excel table name in the input table as showen in the ERROR message. I don't know why this error happen
