Issues Reading a table from Geodatabase
763
05-27-2014 02:44 PM
abhimishra
I have scripted a process to read a CSV file into a file geodatabase. Then, I want to read this imported file and work on it by adding new fields and calculating values. However, while using the arcpy.ListTables() on the geodatabase does not list the table.
I am just confused what is wrong.
Any help !!
Here is my script-------------------------
outLocation = dbLoc+'\\'+ out_name +'.gdb'
arcpy.env.workspace = where_tables_are # the folder where your tables are
# Make list of all tables in workspace
tables = arcpy.ListTables("GDB*")
print tables
try:
    for tb in tables:
    # Execute TableToGeodatabase
        print "Importing "+tb+ " to gdb: " + outLocation
        arcpy.TableToGeodatabase_conversion(tables, outLocation)
env.workspace = os.path.dirname(os.path.dirname(__file__))+'\\'+ out_name +'.gdb'
arcpy.RefreshCatalog(env.workspace)
inTables = arcpy.ListTables()
JamesCrandall
Any help !!
print tables
try:
    for tb in tables:
This should work:
import arcpy
import os
inWS = r'H:\Documents' #the directory that contains the .csv files
outGDB = r'H:\Documents\ArcGIS\Default.gdb' #the output Geodatabase
arcpy.env.workspace = inWS
csvlist = arcpy.ListFiles('*.csv')
print csvlist
for csvfile in csvlist:
   csvname = os.path.splitext(csvfile)[0]
   print "converting " + str(csvname)
   arcpy.TableToTable_conversion(csvfile, outGDB, csvname + '_tab')
Edit: To list the imported tables you just need to set the correct workspace
arcpy.env.workspace = outGDB
tables = arcpy.ListTables("*_tab")
for table in tables:
    print table
    #do the rest of the work here
