Issue: Invalid Expression Failed to Execute (SelectLayerByAttribute)
2742
9
07-24-2024 10:59 AM
KioshiMishiro
I have used ArcGIS Desktop 10.8.2, and I have an issue running the script with an error message about SQL expression in the script written in the title. I would appreciate it if you could support fixing this.
import arcpy
# Define the input and output paths
input_shapefile = r"C:\...\..shp"
output_folder = r"C:\...\(folder)"
# Define the field name that contains unique IDs
unique_id_field = 'AreaKey'
# Create a feature layer from the input shapefile
arcpy.MakeFeatureLayer_management(input_shapefile, "temp_layer")
# Get a list of unique IDs from the shapefile
unique_ids = set([row[0] for row in arcpy.da.SearchCursor(input_shapefile, [unique_id_field])])
# Iterate through each unique ID
for unique_id in unique_ids:
    # Define the SQL query to select the feature by unique ID
    query = '"{unique_id_field}" = {unique_id}'
    # Select the feature using the query
    arcpy.SelectLayerByAttribute_management("temp_layer", "NEW_SELECTION", query)
    # Check if the selection contains any features
    selected_count = int(arcpy.GetCount_management("temp_layer").getOutput(0))
    if selected_count > 0:
        # Define the output shapefile path
        output_shapefile = "{output_folder}\\{unique_id}.shp"
        # Export the selected feature(s) to a new shapefile
        arcpy.CopyFeatures_management("temp_layer", output_shapefile)
        print("Successfully exported {selected_count} feature(s) with ID {unique_id} to {output_shapefile}")
    else:
        print("No features found with the unique ID {unique_id}.")
# Clean up the temporary layer
arcpy.Delete_management("temp_layer")
JoshuaBixby
MVP Esteemed Contributor
Strings must be single-quoted:
query = '"{}" = \'{}\''.format(unique_id_field, unique_id)
CodyPatterson
MVP Regular Contributor
Hey @KioshiMishiro
Looking into this now, but I do see something that could cause an issue. In your where clause, attempt to swap the double quotes with single quotes, like this:
query = "'{unique_id_field}' = {unique_id}"
If this works, let me know!
Cody
KioshiMishiro
Thank you very much @CodyPatterson, but still have same issue like below:
Executing: SelectLayerByAttribute temp_layer NEW_SELECTION "'{unique_id_field}' = {unique_id}"
Start Time: Wed Jul 24 13:17:24 2024
ERROR 000358: Invalid expression
An invalid SQL statement was used.
Failed to execute (SelectLayerByAttribute).
Failed at Wed Jul 24 13:17:24 2024 (Elapsed Time: 0.03 seconds) [...]
JoshuaBixby
A few potential issues.  Firstly, why all the curly brackets?  If you are trying to use Python string formatting, you are missing calling the format function itself.   Assuming the unique_id is a number and not a string, try
query = '"{}" = {}'.format(unique_id_field, unique_id)
KioshiMishiro
That is not a number, but it is a string.
JoshuaBixby
HaydenWelch
In Python 3, the f string syntax is actaully preferred now:
query = f"'{unique_id_field}' = {unique_id}"
 they make it easier to keep track of what is being inserted where because your eyes don't have to keep darting back and forth.
JoshuaBixby
Unfortunately, the OP is using ArcMap 10.8.2, which is Python 2.x.
HaydenWelch
Always forget that Arcmap is still using Python 2...
KioshiMishiro
Thank you all. I solved the issues based on your comments. Really appreciate.
