Is there a way to select a date range instead of a page range when printing Data Driven Pages?
4064
04-24-2015 02:42 PM
JasonDowdy
Using Arc 10.2.2
I have a script that I am using in a geoprocessing service (exposed through a print widget).  As the script currently sits, it has a user defined parameter that allows the user to define what pages from the DDP.mxd to print to pdf.  There is a date field in the feature class called "created_date", format:  4/24/2015 4:56:22 PM.  Is there a way to pass in a date range for the DDP to print instead of using a page range?  I may going about it this all wrong...if so then please at least leave a comment just say I'm an idiot and I'll try to develop this a little more
Here is the script (mainly from ESRI's help site):
import arcpy
import os
import uuid
# The template location in the registered folder
templatePath = '//gis/sharedmaps/Reports/Templates'
# Input WebMap json
Web_Map_as_JSON = arcpy.GetParameterAsText(0)
# Data Driven Page numbers as comma delimited string
DDP_Pages = arcpy.GetParameterAsText(1)
if DDP_Pages == '#' or not DDP_Pages:
    DDP_Pages = "1-4"
# Get the template map document
templateMxd = os.path.join(templatePath, 'Reports.mxd')
# Convert the WebMap to a map document
result = arcpy.mapping.ConvertWebMapToMapDocument(Web_Map_as_JSON,
                                                  templateMxd)
mxd = result.mapDocument
# Use the uuid module to generate a GUID as part of the output name
# This will ensure a unique output name
Output_File = os.path.join(arcpy.env.scratchFolder,
                           'WebMap_{}.pdf'.format(str(uuid.uuid1())))
# Export the WebMap Data Driven Pages to PDF
mxd.dataDrivenPages.exportToPDF(Output_File, "RANGE", DDP_Pages)
# Set the output parameter to be the output PDF
arcpy.SetParameterAsText(2, Output_File)
# Clean up - delete the map document reference
filePath = mxd.filePath
del mxd, result
os.remove(filePath)
DavidBarnes
I don't know how to implement this with python, but if you do a selection first you can then print just the selected pages. This works whether the selection was made through select by location or select by attribute. So you could select by attribute on your date field, then use that to print the selected pages. I hope that helps point you in a useful direction towards a solution.
