Is there a way to ExportToPDF to a single PDF
4302
05-01-2016 11:13 PM
BenVan_Kesteren1
Hi All,
I am currently using this code to export my data driven pages to PDF, but the export seems to only export individual pages, I would like a singular output PDF with several pages instead. Does anyone know if this is possible with this tool, or do I need to use an external module to achieve this one??
mxd = arcpy.mapping.MapDocument("CURRENT")
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
  mxd.dataDrivenPages.currentPageID = pageNum
  arcpy.mapping.ExportToPDF(mxd, r"C:\temp\MAP_" + str(pageNum) + ".pdf")
del mxd
Here is the help file for the ExportToPDF tool
Cheers
FreddieGibson
Honored Contributor
If you leverage the ExportToPDF method of the mapping class you'll have to export each page one at a time and then append them into a single document. If you're using data driven pages and you want to export all of the pages to a single pdf in one go use the exportToPDF method of the data driven pages class instead of the ExportToPDF method of the mapping class.
Data Driven Pages
http://desktop.arcgis.com/en/arcmap/latest/analyze/arcpy-mapping/datadrivenpages-class.htm
I've highlighted the property you're looking for below.
NeilAyres
Export to pdf seems to default to making a multipage pdf.
So, don't change the filename in the loop.
BenVan_Kesteren1
Thanks Neil Ayres​, it seems I was looking for a harder way of doing things than necessary...
BenVan_Kesteren1
Neil seems to have a much 'lighter' answer, but this is the code I used to produce the result I was looking for.
Thanks for your reply Neil, much better answer than mine.
import os, arcpy
#Create final output PDF file
finalFile = r"C:\temp\BensMap.pdf"
if os.path.isfile(finalFile)
  os.remove(finalFile)
  print 'Removed existing output file'
finalPDF = arcpy.mapping.PDFDocumentCreate(finalFile)
  currentPage = str(mxd.dataDrivenPages.currentPageID)
  pageCount = str(mxd.dataDrivenPages.pageCount)
  print 'Exporting page %s of %s' % (currentPage, pageCount)
  tmpPDF = r"C:\temp\MAP_" + str(pageNum) + ".pdf"
  arcpy.mapping.ExportToPDF(mxd, tmpPDF)
  print tmpPDF
  finalPDF.appendPages(tmpPDF)
  del tmpPDF
del mxd
FreddieGibson
Honored Contributor
Data Driven Pages
