Is it possible to write a python code for convert shape file to kml? Please give me the advice and way to do.Thank you
11875
20
05-15-2018 08:17 PM
kanchanarajapaksha
DanPatterson_Retired
you need the full installation of ArcMap, the arcgisscripting checks this, so work on a machine that has a legit version of ArcMap or ArcGIS PRO.  A receiving computer also needs it.
kanchanarajapaksha
Hi,Yes without installation,can I get the resolve the arcgisscripting
problem?
No.
You need the installation or use something that doesn't rely on it
TedKowal
Honored Contributor
Without ArcGIS installed.... geo_file_conv/shp_to_kml.py at master · cleder/geo_file_conv · GitHub   But you will have to trackdown the additional modules and install them in your environment.
kanchanarajapaksha
Please help me to find these additional modules.Because I am new to this
python coding.Thanks a lot
kanchanarajapaksha
Yes.Thanks for your help.Actually, I need the conversion python code.(Shape
file to KML)
you need a 'module' that does the work... the modules are written in python and you will have to download and install them and maybe even to import them in order for it to work.
The code has already been written by others, you just have to use it
kanchanarajapaksha
Hello,Thanks for the reply.Please send me the way to do.(Importing and code
using).Thanks
kanchanarajapaksha
Because I couldnt find it in web
On Thu, May 24, 2018 at 10:20 AM, Kanchana Rajapaksha <
