Is it Possible to Set a Default GDB via Arcpy?
4499
6
03-06-2023 05:01 PM
rescobar
I have tried to write a script to save a copy of a aprx, while changing the default gdb, using the documentation I found at the link below.
aprx.defaultGeodatabase = ....
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/arcgisproject-class.htm
However, this doesn't actually work and the resulting aprx just has the same default gdb as the original aprx I have open. Is there something I'm missing?
import arcpy, os
from arcpy import env
proj_folder = arcpy.GetParameterAsText(0)
outfolder = arcpy.GetParameterAsText(1)
aprx_name = arcpy.GetParameterAsText(2)
aprx = arcpy.mp.ArcGISProject("CURRENT")
new_gdb = proj_folder + "\\Data\\ProjComp\\ProjComp.gdb"
aprx.defaultGeodatabase = new_gdb
aprx.saveACopy(outfolder+"\\"+aprx_name)
DanPatterson
MVP Esteemed Contributor
There was a cavaet in the link
defaultGeodatabase
(Read and Write)
The project's default geodatabase location. The string must include the geodatabase's full path and file name. Note: this property can be set as read-only by an Administrator and therefore it can't be modified.
String
ArcGISProject example 1 shows basically what you have done above, but I wonder if you have to make outfolder and proj_folder the same so that the aprx and gdb are in the same relative positions as the "CURRENT" project
... sort of retired...
rescobar
Thanks, it seems like this yields the same results
ChristopherRoss8
I have had the same experience. The default geodatabase can be set/defined but once you open the aprx you need to add the geodatabase as a database connection. It will then show as the default geodatabase. This is the only workaround I presently am familiar with.
rescobar
Thanks, I take it there's no way to add a database connection in arcpy then?
ChristopherRoss8
Not that I am aware of.
DanPatterson
There is updateFolderConnections in arcpy's mapping class, but it doesn't look like you can simply add a folder you have to replace the existing connections dictionary with a replacement
ArcGISProject—ArcGIS Pro | Documentation
scroll wayyyyy down.
