Is it possible to add a stylex file into an ArcGIS pro Project with Python?
1572
06-25-2021 01:38 AM
Nicorocas
I am creating a script with the arcpy.mp module that allows you to load or update layers to an .aprx project, the problem is when it comes to importing style sheets in an automated way to the project.
Is there a way to import these style sheets into a Project via Python without having to do so from ArcGIS pro?
I'd tried to use aprx.importDocument() method but when I link a stylex file, code breaks with OSError
Code sample and TraceBack:
aprx = arcpy.mp.ArcGISProject("CURRENT")
aprx.importDocument(r"C:\Styles\Burgos.stylx")
File "<string>", line 2, in <module>
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\_mp.py", line 228, in importDocument
return convertArcObjectToPythonObject(self._arc_object.importDocument(*gp_fixargs((document_path, include_layout, reuse_existing_maps), True)))
OSError: C:\Styles\Burgos.stylx
