IOError when calling Style File
1530
06-14-2013 06:05 AM
JiaxinYu
I've started to experiment with batch creating large number of mxd recently. I have been running into an IOError when calling the .style file, and hoping someone can shred some light on the issue.
Here is the code: I'm trying to call a legend item from the user's style file through "arcpy.mapping.ListStyleItems".
import arcpy, os, sys, os.path
##ExportLyr = arcpy.GetParameterAsText(0)
##DummieMXD = arcpy.GetParameterAsText(1)
##MXDforExport = arcpy.GetParameterAsText(2)
##JPEG = arcpy.GetParameterAsText(3)
#EnvironmentalSetting
styleFile = r"C:\Temp\I68078.style"
##styleFile = r'C:\Users\i68078\AppData\Roaming\ESRI\Desktop10.1\ArcMap\I68078.style'
print os.path.isfile(styleFile)
mxd = arcpy.mapping.MapDocument(DummieMXD)
mxd.activeView = 'PAGE_LAYOUT'
df = arcpy.mapping.ListDataFrames(mxd)[0]
styleItem = arcpy.mapping.ListStyleItems(styleFile, "Legend Items", "*")
for l in arcpy.mapping.ListLayoutElements(mxd, "LEGEND_ELEMENT"):
        l.autoAdd=True
        l.elementPositionX = 0.94
        l.elementPositionY = 8.9
        l.elementHeight = 0.25
        l.elementWidth = 0.25
        l.title = "Legend"
        addLayer = arcpy.mapping.Layer(ExportLyr)
        arcpy.mapping.AddLayer(df, addLayer,"TOP")
        for lyr in arcpy.mapping.ListLayers(mxd):
                lyr.showLabels = True
                if lyr.supports("LABELCLASSES"):
                        print lyr.name
                        for lblClass in lyr.labelClasses:
                                if lblClass.showClassLabels:
                                        print lblClass.className
                                        l.updateItem(lyr, styleItem)
styleItem = arcpy.mapping.ListStyleItems(customStylePath, "Legend Items", "ESRI_Style")
df.extent = lyr.getSelectedExtent(True)
df.scale = 6000000
df = 'PAGE_lAYOUT'
arcpy.RefreshActiveView()
mxd.saveACopy(MXDforExport)
arcpy.mapping.ExportToJPEG(mxd, JPEG, df, df_export_width=3000, df_export_height=2200, resolution=150)
print "done"
del arcpy, mxd, addLayer, lyr, df
every time when the code is run, even though os.path.isfile(styleFile) is output as "True". I would get following IOError:
True
  File "C:\Work\Py_Tests\ExportMXD_working.py", line 28, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\mapping.py", line 1599, in ListStyleItems
    return convertArcObjectToPythonObject(arcgisscripting._listStyleItems(*gp_fixargs([style_file_path, style_folder_name, wildcard], True, False)))
IOError: Cannot find style called 'C:\Temp\I68078.style'. Make sure the style file exists.
Thank you for all your help!
J-
JasonScheirer
Esri Alum
Are you using server or 64 bit geoprocessing? .style files are only supported on Desktop, you may need to switch to .serverstyle files.
JiaxinYu
Thank you! The IOError is now gone, but the question that I have now is how do you save a customized style as .ServerStyle file? I haven't been able to find much documentation on it except some sample code that were used for style file ot serverstyle conversion 9.3 and 9.2 ArcGIS.
Thank you for your help,
J-
JasonScheirer
Esri Alum
Convert your .style files to .serverstyle using MakeServerStyleSet.exe, found in C:\Program Files (x86)\ArcGIS\Desktop10.1\bin\MakeServerStyleSet.exe
