Invalid field type with DeleteField_management
650
12-11-2012 05:24 AM
KP
I'm running a script that places all of the fields that I want to delete from a feature class into a list(ListName), but when I run the DeleteField_management I receive the error -
Failed to execute. Parameters are not vaild.  Invalid field type
import arcpy
import os
arcpy.env.workspace = "C:/Data_new/Temp/Default.gdb"
parcel_clip2 = "C:/Data_new/Temp/Default.gdb/parcel_clip2"
fieldList = arcpy.ListFields(parcel_clip2)
ListName = []
fieldstokeep = ["Name1", "Address1", "City", "State", "ZipCode"]
for field in fieldList:
    ListName.append(field.name)
index = 0
while index < len(ListName):
    if ListName[index] in fieldstokeep:
        ListName.remove(ListName[index])
    else:
        index = index + 1
print(ListName)
arcpy.DeleteField_management (parcel_clip2,  ListName)
del ListName
del parcel_clip2
del fieldList
del fieldstokeep
I've been at this awhile and I don;t understand what the issue is.  Any advice?
Thanks!
