Invalid column value with arcpy.da.UpdateCursor
13939
20
12-18-2015 10:00 AM
CCWeedcontrol
I have the following code and i am getting an error on line 76 with the arcpy.da.UpdateCursor that update feature attributes to proper case . I am unsure why. I would really appreciate some help please?
Thanks.
# Import arcpy module
import arcpy
from arcpy import env
# Allow overwrite
# Script user input parameters
polygonLayer = "TaxParcels1" #Taxparcels
pointLayer = "CCAP8" #Point Layer
arcpy.env.workspace = r"Database Servers\15_SQLEXPRESS.gds\CCAPTEST (VERSION:dbo.DEFAULT)" #arcpy.env.workspace = r"Database Servers\15_SQLEXPRESS.gds\TEST (VERSION:dbo.DEFAULT)"
poly = "ACCOUNT_1"
Pnt =  "Account"
sjpoints = "In_memory\sjpoints"
parcelsCount = int(arcpy.GetCount_management(pointLayer).getOutput(0))
dsc = arcpy.Describe(pointLayer)
selection_set = dsc.FIDSet
if len(selection_set) == 0:
    print "There are no features selected"
elif parcelsCount >= 1:
    #Run the Spatial Join tool, using the defaults for the join operation and join type
    arcpy.SpatialJoin_analysis(pointLayer, polygonLayer, sjpoints)
    # define the field list from the spatial join
    sourceFieldsList = ["TARGET_FID", poly,"SiteAddress",'SiteNum_1', 'SiteStreet_1','SiteNumSfx_1','Predir_1','SiteStreet_1','Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1', 'StreetType_1']    #,'StreetType_1'
    # define the field list to the original points
    updateFieldsList = ["OID@", Pnt,"SiteAddres", 'SiteNum', 'StreetName','SiteNumSfx','Predir','SiteStreet', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName', 'StreetType'] #, 'StreetType'
    # Start an edit session. Must provide the workspace.
    edit = arcpy.da.Editor(arcpy.env.workspace)
    # Edit session is started without an undo/redo stack for versioned data
    #  (for second argument, use False for unversioned data)
    edit.startEditing(True)
    # Start an edit operation
    edit.startOperation()
    manualFields =  ["FacltyType","GIS_STEW", "StructType", "Verified", "Status", "StructCat", "APA_CODE",'StreetName'] #,'StreetName'
    with arcpy.da.UpdateCursor(pointLayer, manualFields) as rows:
        for row in rows:
            row[0] = ("Single Family Home")
            row[1] = ("Canyon")
            row[2] = ("Primary, Private")
            row[3] = ("Yes, GRM, TA")
            row[4] = ("Active")
            row[5] = ("Residential")
            row[6] = ("1110")
            row[7] = (sourceFieldsList[4] + " " + sourceFieldsList[12])
            rows.updateRow(row)
        del row
        del rows
    # populate the dictionary from the polygon
    valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)}
    with arcpy.da.UpdateCursor(pointLayer, updateFieldsList) as updateRows:
        for updateRow in updateRows:
            keyValue = updateRow[0]
            if keyValue in valueDict:
                for n in range (1,len(sourceFieldsList)):
                    updateRow = valueDict[keyValue][n-1]
                updateRows.updateRow(updateRow)
        del updateRows
        del updateRow
    #Update feature attributes to proper case
    fields1 = ["StreetName", "SiteStreet","SiteAddres","OwnerName","StreetType"]#,'StreetType'
    with arcpy.da.UpdateCursor(pointLayer, fields1) as cursor:
        for row in cursor:
            row[0] = row[0].title()
            row[1] = row[1].title()
            row[2] = row[2].title()
            row[3] = row[3].title()
            row[4] = row[4].title()
            cursor.updateRow(row)
    # Stop the edit operation.
    #edit.stopOperation()
    # Stop the edit session and save the changes
    edit.stopEditing(True)
arcpy.RefreshActiveView()
#arcpy.Delete_management(sjpoints)
CCWeedcontrol
I have never been able to get Editor to work without commenting out commenting out the stopOperation.
JoshuaBixby
MVP Esteemed Contributor
As the documentation states, calling stopEditing should only be done after an edit operation has been stopped, undone, or aborted.  What is the error message when you don't comment out the line?
CCWeedcontrol
I get the following error
Runtime error
  File "<string>", line 74, in <module>
SystemError: error return without exception set
With the following code
I also attached some data in case anyone wants to look at it.
import arcpy
# Allow overwrite
polygonLayer = "DSD.DBO.TaxParcels1" #Taxparcels
pointLayer = "CCAPTEST.DBO.CCAP5" #Point Layer
arcpy.env.workspace = r"Database Servers\DSD15_SQLEXPRESS.gds\CCAPTEST (VERSION:dbo.DEFAULT)" #arcpy.env.workspace = r"Database Servers\DSD15_SQLEXPRESS.gds\TEST (VERSION:dbo.DEFAULT)"
poly = "ACCOUNT_1"
Pnt =  "Account"
        for row in rows:
            row[1] = ("Canyon")
            row[4] = ("Active")
            row[6] = ("1110")
            rows.updateRow(row)
        del row
        del rows
        del updateRows
        del updateRow
DanPatterson_Retired
print statements please...
ie between 66 and 66 put.   print("key value".format(keyValue))
in fact put a bunch in to see what you are getting.  If it doesn't even get to a print statement, then the problem is before it.
CCWeedcontrol
To try to narrow it down i scaled the code down just to the spatial join.
I ran the following code and got this.
set([u'RD  '])
key value key value key value key value key value key value key value key value key value key value key value key value key value Runtime error Traceback (most recent call last):   File "<string>", line 69, in <module> RuntimeError: Invalid column value [StreetType]
Code:
import arcpy
# Allow overwrite
poly = "ACCOUNT_1"
Pnt =  "Account"
    sourceFieldsList = ['TARGET_FID', poly,'SiteAddress','SiteNum_1', 'SiteStreet_1','SiteNumSfx_1','Predir_1','SiteStreet_1', 'Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1','StreetType_1']    #,'StreetType_1'
    updateFieldsList = ['OID@', Pnt,'SiteAddres', 'SiteNum', 'StreetName', 'SiteNumSfx','Predir','SiteStreet', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName','StreetType'] #, 'StreetType'
    field = 'StreetType'
    values = [row[0] for row in arcpy.da.SearchCursor(pointLayer, (field))]
    uniqueValues = set(values)
    print(uniqueValues)
        del updateRows
        del updateRow
RebeccaStrauch__GISP
I'm not sure if this could cause issues or not, but I notices you have quite a mix of single and double quotes.  Is there a reason?  Can you set them to be one or the other, at least within a particular list?
  1. # define the field list from the spatial join
  2.     sourceFieldsList = ["TARGET_FID", poly,"SiteAddress",'SiteNum_1', 'SiteStreet_1','SiteNumSfx_1','Predir_1','SiteStreet_1','Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1', 'StreetType_1']    #,'StreetType_1'
  3. # define the field list to the original points
  4.     updateFieldsList = ["OID@", Pnt,"SiteAddres", 'SiteNum', 'StreetName','SiteNumSfx','Predir','SiteStreet', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName', 'StreetType'] #, 'StreetType'
CCWeedcontrol
Ya i knew it wasn't clean, been messing with it for a bit. i cleaned her up. Still not able to get past the Invalid column value [StreetType]
Thanks.
oops my bad
print("key value {}".format(keyValue)) forgot the { } in the line.  but at least you know one is bad
CCWeedcontrol
Looks like the problem was that the tax parcels "StreetType" field had 5 spaces after the text (Rd).
by putting in the print statement.
    print(uniqueValues)
it printed
set([u'RD '])
After removing the spaces the code runs without an error but the only other issue is that the StreetName field is not being populated with line
CCWeedcontrol
The following code
import arcpy
# Allow overwrite
poly = "ACCOUNT_1"
Pnt =  "Account"
    print(uniqueValues)
        del updateRows
        del updateRow
    manualFields =  ['FacltyType','GIS_STEW', 'StructType', 'Verified', 'Status', 'StructCat', 'APA_CODE','StreetName'] #,'StreetName'
        for row in rows:
            row[1] = ("Canyon")
            row[4] = ("Active")
            row[6] = ("1110")
            rows.updateRow(row)
        del row
        del rows
        del updateRows
        del updateRow
    fields1 = ['StreetName', 'SiteStreet','SiteAddres','OwnerName','StreetName']
        for row in cursor:
Give me
set([None])
key value
key value
key value
key value
key value
key value
key value
key value
key value
key value
key value
key value
key value
key value 6408
6408 is the points features ObjectID that i have selected to update.
row[7] = (sourceFieldsList[4] + " " + sourceFieldsList[12]). So i guess i am still having issues with the StreetType except for the fact that it doesn't give an error?
