Invalid column value with arcpy.da.UpdateCursor
13936
20
12-18-2015 10:00 AM
CCWeedcontrol
I have the following code and i am getting an error on line 76 with the arcpy.da.UpdateCursor that update feature attributes to proper case . I am unsure why. I would really appreciate some help please?
Thanks.
# Import arcpy module
import arcpy
from arcpy import env
# Allow overwrite
# Script user input parameters
polygonLayer = "TaxParcels1" #Taxparcels
pointLayer = "CCAP8" #Point Layer
arcpy.env.workspace = r"Database Servers\15_SQLEXPRESS.gds\CCAPTEST (VERSION:dbo.DEFAULT)" #arcpy.env.workspace = r"Database Servers\15_SQLEXPRESS.gds\TEST (VERSION:dbo.DEFAULT)"
poly = "ACCOUNT_1"
Pnt =  "Account"
sjpoints = "In_memory\sjpoints"
parcelsCount = int(arcpy.GetCount_management(pointLayer).getOutput(0))
dsc = arcpy.Describe(pointLayer)
selection_set = dsc.FIDSet
if len(selection_set) == 0:
    print "There are no features selected"
elif parcelsCount >= 1:
    #Run the Spatial Join tool, using the defaults for the join operation and join type
    arcpy.SpatialJoin_analysis(pointLayer, polygonLayer, sjpoints)
    # define the field list from the spatial join
    sourceFieldsList = ["TARGET_FID", poly,"SiteAddress",'SiteNum_1', 'SiteStreet_1','SiteNumSfx_1','Predir_1','SiteStreet_1','Postdir_1', 'SiteCity_1', 'SiteZIP_1', 'OwnerName_1', 'StreetType_1']    #,'StreetType_1'
    # define the field list to the original points
    updateFieldsList = ["OID@", Pnt,"SiteAddres", 'SiteNum', 'StreetName','SiteNumSfx','Predir','SiteStreet', 'Postdir', 'SiteCity', 'SiteZip', 'OwnerName', 'StreetType'] #, 'StreetType'
    # Start an edit session. Must provide the workspace.
    edit = arcpy.da.Editor(arcpy.env.workspace)
    # Edit session is started without an undo/redo stack for versioned data
    #  (for second argument, use False for unversioned data)
    edit.startEditing(True)
    # Start an edit operation
    edit.startOperation()
    manualFields =  ["FacltyType","GIS_STEW", "StructType", "Verified", "Status", "StructCat", "APA_CODE",'StreetName'] #,'StreetName'
    with arcpy.da.UpdateCursor(pointLayer, manualFields) as rows:
        for row in rows:
            row[0] = ("Single Family Home")
            row[1] = ("Canyon")
            row[2] = ("Primary, Private")
            row[3] = ("Yes, GRM, TA")
            row[4] = ("Active")
            row[5] = ("Residential")
            row[6] = ("1110")
            row[7] = (sourceFieldsList[4] + " " + sourceFieldsList[12])
            rows.updateRow(row)
        del row
        del rows
    # populate the dictionary from the polygon
    valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)}
    with arcpy.da.UpdateCursor(pointLayer, updateFieldsList) as updateRows:
        for updateRow in updateRows:
            keyValue = updateRow[0]
            if keyValue in valueDict:
                for n in range (1,len(sourceFieldsList)):
                    updateRow = valueDict[keyValue][n-1]
                updateRows.updateRow(updateRow)
        del updateRows
        del updateRow
    #Update feature attributes to proper case
    fields1 = ["StreetName", "SiteStreet","SiteAddres","OwnerName","StreetType"]#,'StreetType'
    with arcpy.da.UpdateCursor(pointLayer, fields1) as cursor:
        for row in cursor:
            row[0] = row[0].title()
            row[1] = row[1].title()
            row[2] = row[2].title()
            row[3] = row[3].title()
            row[4] = row[4].title()
            cursor.updateRow(row)
    # Stop the edit operation.
    #edit.stopOperation()
    # Stop the edit session and save the changes
    edit.stopEditing(True)
arcpy.RefreshActiveView()
#arcpy.Delete_management(sjpoints)
ChadStidham
Are you getting anything at all for the Streetname field?  Based on what you have I'd expect you to get a string of "SiteStreet_1 StreetType_1".  With your code: row[7] = (sourceFieldsList[4] + " " + sourceFieldsList[12]) you are pointing to the list of field name strings (not the actual row values).  I would add those two fields to your list of manual fields when you create the update cursor and point to those row values instead.  You could also do this afterwards with a field calculate.
