Install Arcpy library without ArcGIS server on linux
5035
7
08-13-2019 06:12 PM
JasonLi
Hi Team,
I'm a newbie to ArcGIS, got a request to enable Arcpy on Jupyter Notebook without ArcGIS server bundled on the same Linux machine, is that possible to just install arcpy as a Python 3 library only? I explored some discussions in this community here and most of them are about Jupyter Notebook on Windows environment, in my case is Jupyter Notebook on Linux.
Thanks in advance!
Tags (1)
DanPatterson_Retired
arcpy can't be installed as a separate package, it is part of the ArcMap, ArcGIS Pro or Arc-Whatever distributions that contain it.  Each version is slightly different as far as I can tell
JasonLi
thanks Dan!
JasonLi
Hi Dan,
As your reply said, can I say the structure of Jupyter Notebook(Linux machine1) + ArcGIS Server(Linux machine 2) won't be able to enable Arcpy on Jupyter Notebook, because Arcpy will never be successfully installed.
LukeWebb
Yes, unless you install a copy of ArcGIS Desktop, or alternative ArcGIS suite products that contain arcpy on that machine.   (Im not aware of any "free" products that contain arcpy, but it does come with Desktop basic!)
JasonLi
thanks for the confirmation!
Jason...
If you examine the code associated with the use of Jupyter in say the arcgis 1.6.2 module, you will see that geometries are paralleled by an 'has arcpy' and 'doesn't have arcpy' stream
    _HASARCPY = None
    _HASSHAPELY = None
If you have arcpy, then that filter is triggered and  your geometry is handled largely by arcpy.  If you don't, then you are streamed to what 'shapely' has to offer.  Numpy/Pandas is largely used to handle the attribute stream.
JasonLi
thanks!
