insertRow into SQL server
1685
08-20-2013 01:35 AM
AlexandreDinnouti
I would like to insert an multidimensional array of points into a dataset stored in a SQL Server. Do you guys have a sample code showing how to connect and insertRow?
thanks
Alex
JakeSkinner
Esri Esteemed Contributor
Yes, you can use the InsertCursor with an SDE connection file.  Just set your env.workspace variable to wherever your .sde file is.  Ex:
import arcpy from arcpy import env env.workspace = r"Database Connections\GIS.sde"
JakeSkinner
If you are looking to insert a row into a SQL Server table, take a look at the ArcSDESQLExecute class.  If you are looking to insert a row into an SDE geodatabase table, you can use the InsertCursor function.
AlexandreDinnouti
I saw examples of InsertCursor (arcpy.da) being used to point to a system path, but never to an SQL Server. Is that possible?
thanks,
Alex.
JakeSkinner
