Inserting supporting pages into map book
5010
8
08-04-2015 11:29 PM
KelvinMwakomo
Hello guys...!
Is it possible to insert supporting  pages such as text information, graphs, and tabular data into map book without using python scripts.
If yes, how?
If not, What can i do because i don't know how to use python  and I'm trying to add the supporting pages into my map book.i need your help please..?
Regards!
Kelvin
RobertRogers
I do mine in Acrobat.
KelvinMwakomo
Can you give me a little bit explanation on how to do that?
RobertRogers
Using Acrobat Standard or Pro (i.e., not Reader), you just take all the pdf files and combine them. "Document|Insert Pages".
So the first step is to create all the individual pages you need using whatever software you want, and then combine them. I use Word to make my cover, and I use Illustrator & Photoshop to do various graphics.
KelvinMwakomo
Ok thanks it seems to take a lot of process to complete the task.I think python is the only simple solution.
XanderBakker
Esri Esteemed Contributor
Yeah, I think Python would be easy to implement. See code example here: PDFDocument—Help | ArcGIS for Desktop
DanPatterson_Retired
Xander... getting an 'Unexpected error' message on the link... is this it?
h t t p : / /   desktop.arcgis.com/en/arcmap/latest/analyze/arcpy-mapping/pdfdocument-class.htm
in pure text and having to space out http
KelvinMwakomo
An unexpected error has occurred
it has been flakey... try again, or copy and past the link I posted BUT remove the spaces I embedded
