Inserting a feature into a polygon featureclass with z-values
6091
6
02-10-2015 03:50 AM
MoizIshfaq
Greetings,
I am experiencing a bit wierd response as I would like to create a polygon object and enter its z-values using arcpy. It seems all goes fine interms of execution but when I try to query the newly created object, the z-values are set to zeros. I am using ArcGIS Desktop 10.2 on windows 7. Here is the code snippet.
# Import system modules import arcpy import time, datetime from time import strftime import sys, traceback, os from arcpy import env from arcpy import da   def showMessage(msgText):     arcpy.AddMessage(msgText);     print msgText def showErrorMessage(msgText):     arcpy.AddError(msgText);     print msgText def readGeom(inputFC, fieldNames): ##    infc = arcpy.GetParameterAsText(0)     infc = inputFC     # Enter for loop for each feature     #     # Print the current multipoint's ID     for row in arcpy.da.SearchCursor(infc, fieldNames):         #         showMessage("Feature {0}:".format(row[0]))         partnum = 0         # Step through each part of the feature         #         for part in row[1]:             # Print the part number             #             showMessage("Part {0}:".format(partnum))             # Step through each vertex in the feature             #             for pnt in part:                 if pnt:                     # Print x,y coordinates of current point                     #                     showMessage("{0}, {1}, {2}".format(pnt.X, pnt.Y, pnt.Z))                 else:                     # If pnt is None, this represents an interior ring                     #                     showMessage("Interior Ring:")             partnum += 1  try:     aoiCoords = "5581313.715,3090151.188,88;5581925.211,3085259.218,88;5574281.509,3085259.218,22;5570918.28,3091679.929,55;5575198.75,3093208.669,44"     template = r"PathTo_abc_POL"     arcpy.AddMessage("Starting Processing... " + strftime("%d%b%y"))          spatial_reference = arcpy.Describe(template).spatialReference      ##    env.workspace = out_path ##    arcpy.env.overwriteOutput = True;          dummyPoint = arcpy.Point()     firstPoint = arcpy.Point()     pointsArray = arcpy.Array()          coordsTokens = aoiCoords.split(';')     loopIndex = 0;     for coord in coordsTokens:         coordValues = coord.split(',')         dummyPoint.X = float(coordValues[0]);         dummyPoint.Y = float(coordValues[1]);         dummyPoint.Z = float(coordValues[2]); ##        showMessage("X, Y, Z: " +coordValues[0] + ", " +coordValues[1] + ", " + coordValues[2])         if(loopIndex ==0):             firstPoint = dummyPoint         loopIndex = loopIndex + 1         pointsArray.add(dummyPoint)     #close the polygon     pointsArray.add(firstPoint);     has_z = "ENABLED"     has_m = "DISABLED"     aoiPolygon = arcpy.Polygon(pointsArray, spatial_reference, has_z, has_m)     out_path = arcpy.env.scratchGDB     test1 = "test1"     geometry_type = "POLYGON"     env.workspace = out_path     arcpy.env.overwriteOutput = True;     outFCName = arcpy.CreateFeatureclass_management(out_path, test1, geometry_type, template, has_m, has_z, spatial_reference)     aoiWMName = outFCName.getOutput(0)     cursor = arcpy.da.InsertCursor(test1, ["SHAPE@"])     cursor.insertRow([aoiPolygon])     del cursor          desc = arcpy.Describe(test1)     arcpy.AddMessage("0: HasZ: " + str(desc.hasZ) + ", HasM: " + str(desc.hasM))          readGeom(test1, ["OID@", "SHAPE@"])          arcpy.AddMessage("Processing completed") except Exception as e:     tb = sys.exc_info()[2]     tbinfo=traceback.format_tb(tb)[0]     strMessages = "Exception Type is: " + str(sys.exc_type)     strMessages = strMessages +"\nException Value is: " + str(sys.exc_value)     strMessages = strMessages + "\nFailure Info: " + tbinfo     arcpy.AddError(strMessages)     arcpy.AddError(e.message)
Can someone kindly share any thought or reference on how to fix it? Thanks in advance. Here are the resuts.
Feature 1:
Part 0:
5581313.715, 3090151.188, 0.0
5581925.211, 3085259.218, 0.0
5574281.509, 3085259.218, 0.0
5570918.28, 3091679.929, 0.0
5575198.75, 3093208.669, 0.0
XanderBakker
Esri Esteemed Contributor
The problem is probably due to this line:
When creating a polygon, the "has_z" should be boolean (True,  in your case).
When creating the featureclass the "has_z" is string ("ENABLED" in your case).
Change that line to:
aoiPolygon = arcpy.Polygon(pointsArray, spatial_reference, has_z=True, has_m=False)
XanderBakker
XanderBakker
Just ran this code and it created a PolygonZM (no idea why it is M aware when it is set as False😞
import arcpy
fc_out = r"D:\Xander\GeoNet\Polygon3D\test2.shp"
pnts = aoiCoords.split(';')
arrPnts = arcpy.Array()
sr= arcpy.SpatialReference(102100)
for pnt in pnts:
    crds = pnt.split(',')
    point = arcpy.Point(float(crds[0]), float(crds[1]), float(crds[2]))
    arrPnts.add(point)
polygon = arcpy.Polygon(arrPnts, sr, True, False)
lst_polygons = [polygon]
arcpy.CopyFeatures_management(lst_polygons, fc_out)
DarrenWiens2
Not that this answers the question why the file is M aware, but the issue seems to be in saving to a shapefile. If you run the code saving to an 'in_memory' feature class, it is PolygonZ.
JoshuaBixby
MVP Esteemed Contributor
Called a bug.
DanPatterson_Retired
Discovered this little ditty...
  - buried in the bowels of hell.... aka .... the help files.
  - http://resources.arcgis.com/en/help/main/10.2/index.html#/Output_has_M_values/001w00000007000000/
  - For shapefiles, storage of M and Z values is closely connected;
    if the output has Z, then regardless of this environment setting,
    the output will also have M.
MoizIshfaq
Thanks everyone for your comments. Xander pointed it correctly as I somehow was using arcpy.Polygon and arcpy.CreateFeatureclass_management methods in my original script, both methods use the same variables 'has_m and has_z' and I didn't pay attention to them as they both take different values and data types. Once again a round of applaud for Xander .
I forgot to mention that arcpy exception handling didn't help in catching this error.
