Insert.cursor Error While Copying Geometries
3901
6
03-24-2022 04:41 PM
Jefcoat_Nathan
I'm trying to insert/create geometries using "feature A" geometries  into feature B, which has null geometries .  It seems simple enough but I'm not well acquainted with programming.  This is what I have:
import arcpy
#Setup environment and variables
arcpy.env.workspace = r'C:\\Users\\xxxx\\OneDrive - xxxxxxx, BUREAU OF TECH. SERVICES\\Documents\\ArcGIS\\Projects\\Migration\\ Migration.gdb'
A = 'Easement_for_Treat'
idfieldA = 'IDFieldA'
B = "Work_Area_Migration_Merge"
idfieldB = 'IDFieldB'
#Build a dictionary with IDs as keys and geometries as value
geometries = {key:value for (key,value) in arcpy.da.SearchCursor(A, [idfieldA, 'SHAPE@'])}
#Empty list to store ids in B not found in A
notfound = []
#Insert B with geometries from A where ID:s match
with arcpy.da.InsertCursor(B, [idfieldB, 'SHAPE@']) as cursor:
    for row in cursor:
        try:
            row[1] = geometries[row[0]]
            insert.updateRow(row)
        except:
            notfound.append(row[0])
I get thrown this exception:
TypeError                                 Traceback (most recent call last)
In  [2]:
Line 18:    for row in cursor:
TypeError: 'da.InsertCursor' object is not iterable
 Any guidance would be greatly appreciated!
JohannesLindner
As the others have said, you can't iterate an InsertCursor.
You want to update existing features in class B, so you need an UpdateCursor.
Starting from line 17 in your code:
with arcpy.da.UpdateCursor(B, [idfieldB, 'SHAPE@']) as cursor:
    for key, shape in cursor:  #iterate through the existing features in B
        try:
            new_shape = geometries[key]
            cursor.updateRow([key, new_shape])
        except KeyError:
            notfound.append(key)
Have a great day!
Johannes
DanPatterson
MVP Esteemed Contributor
an updatecursor would be a better bet if you are altering existing data
UpdateCursor—ArcGIS Pro | Documentation
it supports "with" syntax
... sort of retired...
by Anonymous User
Not applicable
You don't iterate an InsertCursor (for row in cursor) since you're just adding rows. try something like this
iCur = arcpy.da.InsertCursor(table, ["ID", "SHAPE@X", "SHAPE@Y"])
for k, v in geometries.items():
    row = (k, v[0], v[1])
    iCur.insertRow(row)
I've never tried to insert a complete shape object which is why I split it out in the example. that may be unnecessary.
also, if you're trying to update an existing records with geometries, you'd want to use an UpdateCursor.
JohannesLindner
        try:
        except KeyError:
Have a great day!
Johannes
Jefcoat_Nathan
Thanks for the help. I've updated the code but I'm getting thrown a NameError on insert.updateRow
arcpy.env.workspace = r'C:\\Users\\xxx\\OneDrive - CITY OF xxxx, BUREAU OF TECH. SERVICES\\Documents\\ArcGIS\\Projects\\xxxxxxxx\\xxxxxxx Migration.gdb'
geometries = {key:value for (key,value) in arcpy.da.SearchCursor(A, [idfieldA, 'SHAPE@Area'])}
notfound = []
        try:
            insert.updateRow([key, new_shape])
        except KeyError:
NameError                                 Traceback (most recent call last)
In  [5]:
Line 19:    insert.UpdateRow([key, new_shape])
NameError: name 'insert' is not defined
 Do I have the syntax wrong?
Jefcoat_Nathan
I changed it to cursor.updateRow and it worked. Thank You!
JohannesLindner
Oops, I didn't change all of the variable names... Fixed it in my answer.
Have a great day!
Johannes
