inconsistent Arcpy.Mapping behaviour
8226
28
07-31-2014 10:55 AM
JoshuaChan
I've written a script using Arcpy.mapping module to automate map making. It works as a one-off for use in ArcMap if I use the ArcToolbox to call the script. But if I call it from python (eclipse) I get weird error messages ("ExecuteError: ERROR 000358: Invalid expression") pointing towards the "Select by Layer" tool. But it executes fine if run from ArcToolbox, no errors... same script.
Part 2: I gave up running it from Eclipse and ran it from ArcToolbox within ArcMap. Now I'm trying to run a batch - multiple maps. It used to work until this morning. this morning I made the most minor of changes... to check to see if a variable.upper() == 'YES'
again, this works in the "one-off" scenario within ArcMap called from ArcToolbox. But I'm trying to run my batch script (also called by ArcToolbox) and I get that same query error as above. Why is that? it's the exact same script. I don't want to interactively run this script in ArcMap for all 350+ maps. Why is arcpy.mapping so flaky? Is there a way to fix this???
JoshuaChan
I asked our server administrator and here's what patches we have:
ArcGIS 10.1 for Desktop
  ArcGIS 10.1 SP1 for Desktop
  ArcGIS 10.1 SP1 for Desktop Set Bing Key Patch
  ArcGIS 10.1 SP1 for Desktop Quality Improvement Patch
I'm not sure how this affects this strange bug where my program works one at a time but not in a batch. I've changed the query format as you suggested.
So after using the string format syntax example, instead of the update layer error (as per yesterday) it is giving me the older query format error again:
Executing: batchMap4PMV
Start Time: Fri Aug 08 08:04:35 2014
Running script batchMap4PMV...
checking out inset map placement: None
no inset map
beginning layer filter of data frameLayers
CROWN_LANDS_FILE = '2411100'
Tantalis Files
defined the lyr for Tantalis Files?
Failed to execute (SelectLayerByAttribute).
  File "W:\srm\sry\Local\projlib\2014-15\Auth_Lands_PMV\data\scripts\batchMapRobot.py", line 80, in <module>
    runMapRobotScript(filenum, outfile)
  File "W:\srm\sry\Local\projlib\2014-15\Auth_Lands_PMV\data\scripts\batchMapRobot.py", line 42, in runMapRobotScript
    obj.dataFrameFilter(obj.mainDF, obj.mainDefQry, inset_map)
  File "W:\srm\sry\Local\projlib\2014-15\Auth_Lands_PMV\data\scripts\map_robot_2014_PMV_v2_4batch.py", line 163, in dataFrameFilter
    arcpy.SelectLayerByAttribute_management(lyr,"NEW_SELECTION", defQry)
  File "e:\sw_nt\arcgis\desktop10.1\arcpy\arcpy\management.py", line 6498, in SelectLayerByAttribute
    raise e
Failed to execute (batchMap4PMV).
Failed at Fri Aug 08 08:04:43 2014 (Elapsed Time: 8.00 seconds)
XanderBakker
Esri Esteemed Contributor
I suppose that if you manually apply the definition query CROWN_LANDS_FILE = '2411100' to the layer, it works without any problems, right? If so, then the definition query is not the problem. It might be the layer itself or other aspects of the environment you're working in. Those are hard to solve without access to the data and mxd you're using.
I would probably step away from using of classes and rewrite the code using the da cursors and set the extent using the geometry rather than selecting and zooming to the extent of the selection.
JoshuaChan
I don't understand why the code works as a one off but not in the looped scenario.
I'll have to read up on da cursors vs regular run of the mill cursors.
as for the geometry thing, can you send me a link to that? The one you sent previously was talking about exporting to shapefile, not zooming to an extent.
JoshuaChan
my time is pretty limited so I'm trying to avoid having to rewrite the entire thing. That may take me as much time as manually doing this one at a time.
JoshuaChan
plus without knowing what the real problem is, i'm hesitant to rewrite it not knowing if that will actually fix the (unknown) problem.
JoshuaChan
sorry, i see now the notes you put in there for lines 35-37 for map extent setting. more reading to do....
XanderBakker
Although it seems as a lot of work to rewrite the code, it might pay off in the long run...
XanderBakker
This is a good place to start reading on Accessing data using cursors‌ and obviously SearchCursor (arcpy.da)
JoshuaChan
I've discovered the reason behind the "select by attribute" error but not the reason behind the UpdateLayer error.
The SelectByAttribute kept popping up because I was not yet connected to the SDE. rather than give me a dialog box to log in - it just returned an error. I don't know how to fix that other than to open up the MXD, connect to the SDE, then close the MXD and run the script from the ArcToolbox in a blank new mxd. Seems kinda hokey but thats all i could think of for now.
BUt the Update Layer part is still broken... In my script instead of printing out the name of my "Dimensions" layer I decided to print out all the layer names. I can see all the layers EXCEPT for "Dimensions". I re-open my MXD and I can see a layer named "Dimensions". It has something in the Attribute table so it's not an empty layer. I remove it... I re-add it. and hit Save. I re run the script and same problem... ListLayers does not show "Dimensions" even though it really is there.
This might be the sticking point... why does the layer not want to show up in the batch version of the script?
JoshuaChan
so I haven't touched this for a week. I copied my old mxd and re-ran the program with no changes to the script. Now the error message is different:
  File "W:\srm\sry\Local\projlib\2014-15\Auth_Lands_PMV\data\scripts\batchMapRobot.py", line 46, in runMapRobotScript
    obj.doDimensions(obj.mainDF, tantlyr)
  File "W:\srm\sry\Local\projlib\2014-15\Auth_Lands_PMV\data\scripts\map_robot_2014_PMV_v2_4batch.py", line 230, in doDimensions
    arcpy.mapping.UpdateLayer(dFrame, upLyr, srcLyr, False)
  File "e:\sw_nt\arcgis\desktop10.1\arcpy\arcpy\utils.py", line 181, in fn_
    return fn(*args, **kw)
  File "e:\sw_nt\arcgis\desktop10.1\arcpy\arcpy\mapping.py", line 1869, in UpdateLayer
    assert isinstance(update_layer, Layer)
AssertionError
I placed a whole bunch of add message statements to see where exactly it was bombing and it's on the UpdateLayer line.
Again, this script runs without error when I'm doing it one at a time in ArcMap via ArcToolbox. But when trying to run as a batch - namely have a script call the original script with a bunch of arguments - it bombs. The error message doesn't make much sense to me and so far every online answer to similar queries point to people sending a text string to the UpdateLayer function instead of a map document object or a layer object.  If you check my script (it's still on the FTP site listed above) I'm fairly certain I have sent it map document object and layer object.
Any help much appreciated.
