Import Script greyed out
1606
11-28-2012 02:19 PM
RobertMartin2
I've noticed that at (seemingly) random intervals the Import Script option in the right-click menu for Python tools will grey out, like so:
[ATTACH=CONFIG]19593[/ATTACH]
If the script is cached as well (which is usually the case), the only option is to create a whole new interface. This is starting to get pretty frustrating. Does anyone know why this happens - or better yet - how to fix it?
Many thanks.
BruceRea
I have encountered this very same issue and have found that if you EXPORT the script, it unlocks the IMPORT script option on the menu.  However, if you intuitively click on IMPORT to bring in a new script (replace), it just brings in the same script that was exported.  However, if you click on PROPERTIES, you can import a new script.  Hmmmm...  Does that help? 2 yrs later!  hahahahaaa : ))
