if then statement in field calculator, string to integer
3061
8
03-04-2014 05:16 AM
DavidKoch1
I am having a heck of a time trying to write an if elif script in the field calculator. I've read numerous threads but can't figure out how to do it right. I have a field called route_ty_1 that is a string field, with possible attributes of "Bus," "Rail," "LightRail," etc. For a given attribute, I want a code number to be returned for the site_code field, which is short integer. Here is the code I have been tinkering with:
Pre-logic script code:
def Reclass(site_code):
  if route_ty_1 == 'Bus':
    return 338
  elif route_ty_1 == 'LIGHT RAIL':
    return 281
  elif route_ty_1 == 'METRO':
    return 335
  elif route_ty_1 == 'Rail':
    return 282
  elif route_ty_1 == 'Commuter Bus':
    return 336
site_code =
Reclass(!site_code!)
If there is a better way to do this than if statements I am very open to suggestions! Thanks!
JamesCrandall
I am terrible with the field calculator myself, but shouldn't it be (emphasis in bold):
def Reclass(route_ty_1):
    return 338
    return 281
    return 335
    return 282
    return 336
Also, maybe have an 'else' in the statement as well to pickup anything that doesn't evaluate in your if statement.
edit: upvoted Joshua's solution v:  a  more complete answer.  Mine was lazy 🙂
JoshuaChisholm
Hello David,
There are some interesting options here.
That being said, I often use the else if method. If I may suggest a few things, I would add a .lower() (makes it case insensitive) and a .strip() (gets rid of any leading or trailing whitespace) to make sure you are matching as many of the cases as possible. I'd also add a else to catch any records that don't match at all.
  site_code=site_code.lower().strip()
  if site_code == 'bus':
    return 338
  elif site_code == 'light rail':
    return 281
  elif site_code == 'metro':
    return 335
  elif site_code == 'rail':
    return 282
  elif site_code == 'commuter bus':
    return 336
  else:
    return 0
Good luck!
DavidKoch1
Thanks Joshua--should there be anything in the .lower and .strip parentheses?
Hello David,
    return 338
    return 281
    return 335
    return 282
    return 336
  else:
    return 0
Good luck!
JoshuaChisholm
Nope!
If you want, you can specify characters you want removed from the front and end of a string with the strip() function, but leaving it empty will remove whitespace by default.
DavidKoch1
Thanks--I am getting the following errors:
ERROR 000539: Error running expression: Reclass(0)
  File "<expression>", line 1, in <module>
  File "<string>", line 2, in Reclass
AttributeError: 'int' object has no attribute 'lower'
Failed to execute (CalculateField).
Nope!
JoshuaChisholm
I think you're calculating on the wrong field. Based on the strings you're looking for (in the if statements), the input should be a string (not an integer/number).
Make sure the expression reads something like Reclass(!inputTansitType!) .
It might actually be less confusing if you changed the variable name in the code book:
def Reclass(inputTansitType):
  inputTansitType=inputTansitType.lower().strip()
  if inputTansitType== 'bus':
    return 338
  elif inputTansitType== 'light rail':
    return 281
  elif inputTansitType== 'metro':
    return 335
  elif inputTansitType== 'rail':
    return 282
  elif inputTansitType== 'commuter bus':
    return 336
  else:
    return 0
Sorry if I caused any confusion!
MathewCoyle
Honored Contributor
As an aside, I find it much easier to use a dictionary in these cases.
reclass_dict = {'bus': 338,
        'light rail': 281,
        'metro': 335,
        'rail': 282,
        'commuter bus': 336,
    inputTansitType = inputTansitType.lower().strip()
    try:
        return reclass_dict[inputTansitType]
    except:
        return 0
DavidKoch1
Thanks everyone for your help! Joshua, you were right about calculating on the wrong field. Mathew's method also worked great.
