if else loop problem
1361
6
04-24-2013 05:15 AM
ScottMacDonald
I have written a script for toolbox that selects cities and outputs them to a table (citylist).  It all works apart from the if....else part.
if: maximim kilometres to interstates > 0:
    subselect cities within x km of interstates
else:
    use citylist
It works fine if users input a figure > 0 but not if it is <= 0 or text - then the program gets stuck in a loop and doesn't stop.
Any help as to where I'm going wrong would be appreciated.
# import system modules
import arcpy, os, arcpy, string
from arcpy import env
arcpy.env.overwriteOutput = True
# get user supplied path, layers and fields
path = arcpy.GetParameterAsText(0) # path is H:\working\Findsites.gdb
cities = arcpy.GetParameterAsText(1) # cities Layer is cities Feature Layer cities.shp
cities2 = "cities2"
citiesL = "citiesL"
counties = arcpy.GetParameterAsText(2) # counties Layer is counties Feature Layer counties.shp
counties2 = "counties2"
countiesL ="countiesL"
interstates = arcpy.GetParameterAsText(3) # interstates Layer is Feature Layer interstates.shp
interstates2 = "interstates2"
interstatesL = "interstatesL"
crimeField = arcpy.GetParameterAsText(4) # crimeField is fieldname 'CRIME_INDE' SQL expression
crimeval = arcpy.GetParameterAsText(5) # crime index is CRIME_INDE and is a Double 0.02
whereClause = "{0} <= {1}".format(arcpy.AddFieldDelimiters(citiesL, crimeField), crimeval)
universityField = arcpy.GetParameterAsText(6) # universityField is fieldname 'UNIVERSITY' SQL expression
universityval = arcpy.GetParameterAsText(7) # universityfieldindex is the UNIVERSITY field and is string integer 1
whereClause2 = "{0} = {1}".format(arcpy.AddFieldDelimiters(citiesL, universityField), universityval)
workforceField = arcpy.GetParameterAsText(8) # workforceField is fieldname 'AGE_18_64' SQL expression
workforceval = arcpy.GetParameterAsText(9) # workforce index is attribute of AGE_18_64 field and is a Double and is 25000
whereClause3 = "{0} >= {1}".format(arcpy.AddFieldDelimiters(countiesL, workforceField), workforceval)
farmField = arcpy.GetParameterAsText(10) # farmField is fieldname 'NO_FARMS87' SQL expression
farmval = arcpy.GetParameterAsText(11) # farmfieldindex is the NO_FARMS87 field and is Double integer is 500
whereClause4 = "{0} >= {1}".format(arcpy.AddFieldDelimiters(countiesL, farmField), farmval)
maxKmInterstate = arcpy.GetParameterAsText(12) # interstate WITHIN_A_DISTANCE linear unit
nearestInterstate = arcpy.GetParameterAsText(13) # Near Table Analysis table generated
citylist = arcpy.GetParameterAsText(14) # narrowed down cities list temporary
citylistL = "citylistL" # the temporary feature layer of the generated cityList feature class
outputLayer = arcpy.GetParameterAsText(15) # ootput
# make cities feature layer and remove unnecessary fields
arcpy.CopyFeatures_management(cities, cities2)
arcpy.MakeFeatureLayer_management(cities2, citiesL)
arcpy.DeleteField_management(citiesL, ["POPULATION", "TOTAL_CRIM"])
if crimeField == "CRIME_INDE" and universityField == "UNIVERSITY":
arcpy.SelectLayerByAttribute_management(citiesL, "NEW_SELECTION", whereClause + " AND " + whereClause2)
arcpy.AddMessage("Maximum crime index threshold and cities with universities selected")
elif crimeField == "CRIME_INDE" and universityField <> "UNIVERSITY":
arcpy.SelectLayerByAttribute_management(citiesL, "NEW_SELECTION", whereClause)
arcpy.AddMessage("Maximum crime index threshold selected")
arcpy.DeleteField_management(citiesL, "UNIVERSITY")
arcpy.CopyFeatures_management(citiesL, citylist)
elif crimeField <> "CRIME_INDE" and universityField == "UNIVERSITY":
arcpy.SelectLayerByAttribute_management(citiesL, "NEW_SELECTION", whereClause2)
arcpy.AddMessage("Cities with a university selected")
arcpy.DeleteField_management(citiesL, "CRIME_INDE")
elif crimeField <> "CRIME_INDE" and universityField <> "UNIVERSITY":
arcpy.AddMessage("No crime threshold or cities with universities selected")
arcpy.DeleteField_management(citiesL, ["CRIME_INDE", "UNIVERSITY"])
# make counties feature layer and remove unnecessary fields
arcpy.CopyFeatures_management(counties, counties2)
arcpy.MakeFeatureLayer_management(counties2, countiesL)
arcpy.DeleteField_management(countiesL, ["AREA", "PERIMETER", "POP1990", "POP_SQMILE", "SQ_MILES", "GAVPRIMARY", "X", "Y", "X_1", "Y_1"])
if workforceField == "AGE_18_64" and farmField == "NO_FARMS87":
arcpy.SelectLayerByAttribute_management(countiesL, "NEW_SELECTION", whereClause3 + " AND " + whereClause4)
arcpy.AddMessage("Minimum workforce and proximity to farms selected")
arcpy.CopyFeatures_management(countiesL, "countylist")
elif workforceField == "AGE_18_64" and farmField <> "NO_FARMS87":
arcpy.SelectLayerByAttribute_management(countiesL, "NEW_SELECTION", whereClause3)
arcpy.AddMessage("Minimum workforce selected")
arcpy.DeleteField_management(countiesL, "NO_FARMS87")
elif workforceField <> "AGE_18_64" and farmField == "NO_FARMS87":
arcpy.SelectLayerByAttribute_management(countiesL, "NEW_SELECTION", whereClause4)
arcpy.AddMessage("Proximity to farms selected")
arcpy.DeleteField_management(countiesL, "AGE_18_64")
elif workforceField <> "AGE_18_64" and farmField <> "NO_FARMS87":
arcpy.AddMessage("No minimun workforce or proximity to farms selected")
arcpy.DeleteField_management(countiesL, ["AGE_18_64", "NO_FARMS87"])
# from selection above select cities intersecting counties
arcpy.SelectLayerByLocation_management(citiesL, "INTERSECT", "countylist", "", "SUBSET_SELECTION")
# create a city list if maximum distance to interstates selected
if maxKmInterstate >0:
arcpy.AddMessage("Maximum distance to interstates selected")
# copy interstates feature class so original is unaffected
arcpy.CopyFeatures_management(interstates, interstates2)
# make interstates feature layer
arcpy.MakeFeatureLayer_management(interstates2, interstatesL)
# further select cities within maximum interstate distance
arcpy.SelectLayerByLocation_management(citiesL, "WITHIN_A_DISTANCE", interstatesL, maxKmInterstate, "SUBSET_SELECTION")
# copy to citylist
# create a feature layer from new citylist
arcpy.MakeFeatureLayer_management(citylist, citylistL)
# Generate NearTable_analysis to find closest interstate distance
arcpy.GenerateNearTable_analysis(citylistL, interstates, nearestInterstate, maxKmInterstate)
# join nearest interstate column to citylist
arcpy.JoinField_management(citylistL, "FID", nearestInterstate, "IN_FID", "NEAR_DIST")
# divide distance to interstates by 1000 to convert to kilometres
# arcpy.CalculateField_management(citylistL, "NEAR_DIST", '!NEAR_DIST!/1000')
# spatially join the narrowed down city/road and counties layers remove unwanted fields and rename others
arcpy.SpatialJoin_analysis(citylistL, countiesL, outputLayer, "#", "#", "")
else:
arcpy.AddMessage("No maximum distance to interstates selected")
# create city list where no maximum interstate distance selected
# update citylist with relevant fields from counties join
# Set data path
intable = "H:/working/CityTable.shp"
# Get the fields from the input
fields= arcpy.ListFields(intable)
# Create a fieldinfo object
fieldinfo = arcpy.FieldInfo()
# Iterate through the fields and set them to fieldinfo
for field in fields:
    if field.name == "NAME":
        fieldinfo.addField(field.name, "CITYNM", "VISIBLE", "")
    elif field.name == "CRIME_INDE":
        fieldinfo.addField(field.name, "CRIMEINDX", "VISIBLE", "")
    elif field.name == "UNIVERSITY":
        fieldinfo.addField(field.name, field.name, "VISIBLE", "")
    elif field.name == "NEAR_DIST":
        fieldinfo.addField(field.name, "INTRSTkm", "VISIBLE", "")
    elif field.name == "NAME_1":
        fieldinfo.addField(field.name, "COUNTYNM", "VISIBLE", "")
    elif field.name == "AGE_18_64":
        fieldinfo.addField(field.name, "WORKFRCE", "VISIBLE", "")
    elif field.name == "NO_FARMS87":
        fieldinfo.addField(field.name, "FARMS", "VISIBLE", "")
#elif field.name == "Join_Count":
    #    fieldinfo.addField(field.name, field.name, "HIDDEN", "")
    elif field.name == "TARGET_FID":
    elif field.name == "OBJECTID":
    elif field.name == "Shape_Leng":
    elif field.name == "Shape_Le_1":
    elif field.name == "Shape_Area":
    elif field.name == "ID":
# The created crime_view layer will have fields as set in fieldinfo object
arcpy.MakeTableView_management(intable, "CityView", "", "", fieldinfo)
# To persist the layer on disk make a copy of the view
arcpy.CopyRows_management("CityView", "H:/working/CityView.dbf")
print arcpy.GetMessages()
[\CODE]
JakeSkinner
Esri Esteemed Contributor
Hi Scott,
You can check whether a variable is an integer using 'isinstance'.  Try writing the if/else loop as:
if isinstance(maxKmInterstate, (float, int)) and maxKmInterstate > 0:
    <code>
else:
    <code>
Also, when posting your code your have your closing tag wrong [\CODE].  It should be .  An easy approach is select your code and click the # symbol in the header and the CODE tags will automatically be added to the selected text.
ScottMacDonald
Thanks JSkinn3,
That line of code worked perfectly, thanks for the answer and for replying so quickly - much appreciated.
I'll make sure I use the correct    tags next time.
Regards
Scottaidh
ScottMacDonald
Hi JSKinn - The code you sent to solve the if else problem  (isinstance) doesn't work when the user inputs 0 Kilometers - it goes into a loop and doesn't stop.  Do you know a way round this?  code below.
cities2 = "cities2"
citiesL = "citiesL"
newFieldName = "DISTANCE"
citylist = arcpy.GetParameterAsText(14) # narrowed down cities list temporary and set to derived to hide
outputLayer = arcpy.GetParameterAsText(15) # oot layer set to derived
outputTable = arcpy.GetParameterAsText(16) # output table
if isinstance(maxKmInterstate, (float, int)) or maxKmInterstate > 0:
 # copy to citylist
 # add new DISTANCE field as short integer
 arcpy.AddField_management(nearestInterstate, newFieldName, "SHORT")
 #Calculates the new DISTANCE field by dividing metres by 1000
 arcpy.CalculateField_management(nearestInterstate, newFieldName, "!NEAR_DIST! / 1000", "PYTHON", "")
 # join city list to nearest interstate table
 arcpy.JoinField_management(citylistL, "FID", nearestInterstate, "IN_FID", "DISTANCE")
else:
arcpy.AddMessage("Creating City table based on selections.......")
# Set data path
intable = outputLayer
    elif field.name == "DISTANCE":
# The created city view layer will have fields as set in fieldinfo object
arcpy.CopyRows_management("CityView", outputTable)
arcpy.AddMessage("Your City Table file has been created")
ScottMacDonald
Hi JSkinn.  The line of code you suggested below for the if .. else.. condition didn't work after all.  It only worked when I changed the and to an or but it didn't solve the problem if a user types in 0 or anything else.  It goes into a loop.  Do you perhaps have any other suggestions?
    <code>
else:
    <code>
cities2 = "cities2"
citiesL = "citiesL"
crimeval = arcpy.GetParameterAsText(5) # Double 0.02
workforceval = arcpy.GetParameterAsText(9) # Double and is 25000
farmval = arcpy.GetParameterAsText(11) # Double integer is 500
# make cities copy and cities feature layer and remove unnecessary fields
# select only user chosen fields for cities whereClause
# select only user chosen fields for counties whereClause
if isinstance(maxKmInterstate, (float,int)) or maxKmInterstate > 0:
 # copy to citylist
else:
# Set data path
JakeSkinner
I'm not sure it goes into a loop with an "if/else" statement.  Infinite loops are usually created from "while" statements.  I would recommend adding some more arcpy.AddMessage commands to see exactly what is going on.
curtvprice
Scott:
Warning: your code has mixed indents, some tabs, some spaces. It's best to use one or the other, I like spaces.  This can lead to unexpected results as your indents may not work exactly as intended.
Most Python IDEs have a setting to convert automatically to spaces for you.
