I want to know wich of the tools can make a map like this one?
2529
8
02-13-2018 07:34 PM
VictorPerez1
Hi guys, I want to do this kind of maps, actually I don't recognize what's the specific tool. But i have points with information so I would like to make it.
RichardFairhurst
I cannot access the image you linked, so I don't know what the map looks like.
VictorPerez1
Hi Richar, can you see now?
DanPatterson_Retired
There is no one tool that makes that map.  It is the result of an analysis process
VictorPerez1
So...what steps i have to follow to do this kind of analysis?
JamesMacKay3
As that's a web map, it could be as simple as publishing a feature layer using ArcGIS Server or ArcGIS Online, creating a web map and applying a heat map renderer to your layer.  How it turns out depends on what your point data look like though.
You also have this posted in the Python place.
Why do you think python is needed as well?
RebeccaStrauch__GISP
You will have to take a snapshot of the map you are trying to creat, and give a little more information about how you data points are stored.  Are they in an excel spreadsheet? A shapefile? A feature class?
what software do you have access to?  ArcGiS online account only? (Organization or personal/public?)  ArcPro? ArcGIS Desktop? Enterprise? (and versions)   Are you looking to develop using Python (as Dan asked) or maybe the API for Python (different than just Python/arcpy) or maybe a web map using JavaScript?
lots of questions, I know.  And a picture we can see would help answer some of this maybe.  Many here willing to help, but not enough info yet for us to answer.
