I NEED TO EXTRACT THE FIRST LETTER AND THE MIDDLE LETTER OF A STRING ATTRIBUTE VALUE
9291
20
05-23-2013 01:57 PM
OLANIYANOLAKUNLE
I NEED TO EXTRACT THE FIRST LETTER AND THE MIDDLE LETTER OF A STRING ATTRIBUTE VALUE I.E "FIGURINE" , I WANT TO EXTRACT LETTER "F" & "R" TO FORM "FR". PLEASE HELP ME
RhettZufelt
MVP Notable Contributor
Please how can i handle the issue of schema Lock? This schema lock issue is really getting on my nerves.
Best way I have found is to have each script spawned in a separate python process.  So, I have code similar to the following as my main "control" script:
import os
buildings = r"C:\arcgisserver\python\buildings.bat"
mapping = r"C:\arcgisserver\python\mapping.bat"
MRs = r"C:\arcgisserver\python\MRs.bat"
finish = r"C:\arcgisserver\python\finish.bat"
os.system(mapping)
os.system(buildings)
os.system(MRs)
os.system(finish)
Then, the respective .bat files would be similar to:
cd C:\Python27\ArcGIS10.1
Python C:\arcgisserver\python\buildings.py
Exit
This way, a sepratate python process is spawned to run each script.  When it hits the "Exit" in the batch file, it closes that python process and releases ALL lock files.  then it moves on to the next script.
Hope this helps,
R_
