reproject all feature classes to different fgdb in Python script
3304
05-28-2013 05:08 AM
RobertBuckley
I would like to write a script which does the following;
1. Lists all feature classes in a geodatabase
2. Checks that all the feature classes have a defined coordinate system - if not, then stop script and output message
3. If nr 3 passes, then reproject all the featureclasses into a certain coordinate system using a specific transformation method
4. All reprojected feature classes should be saved into a predefined different geodatabase
5. Output message when successful
import arcpy, os
from arcpy import env
# Set this to the input FGDB
env.workspace = r'Path_to_old_GDB.gdb'
Dir = env.workspace
env.overwriteOutput = 1
# Variables
gdb_out = r'Path_to_new_GDB.gdb'
sr = r'Path_to_new_CRS.prj'
# Parameters for script tool
# Input FGDB
env.workspace = arcpy.GetParameterAsText(0)
# Target FGDB
gdb_out = arcpy.GetParameterAsText(1)
# List the old FDs
dslist = arcpy.ListDatasets("", "Feature")
# Add old FDs to target FGDB (FC will be projected in new FDs)
if dslist == "Null":
    pass
else:
    for ds in dslist:
        arcpy.CreateFeatureDataset_management (gdb_out, ds, sr)
        # List FCs in FDs and copy them to new FDs
        fclist = arcpy.ListFeatureClasses("","",ds)
        for fc in fclist:
            arcpy.CopyFeatures_management(fc, os.path.join(gdb_out, ds, fc))
# Finally, add/project any standalone FCs to the new FGDB
for infc in arcpy.ListFeatureClasses():
        ds = arcpy.Describe(infc)
        if ds.featureType == "Simple":
            # Determine if the input has a defined coordinate system, can't project it if it does not
            dsc = arcpy.Describe(infc)
            if dsc.spatialReference.Name == "Unknown":
                print ('Undefined Coordinate System:  ' + infc)
            else:
                # run project tool
                arcpy.Project_management(infc, os.path.join(gdb_out, infc), sr)
        else:
            print 'No stand alone feature classes to copy'
This is what I have so far....doesn´t work as I want though.
There is no option for the transformation method and the dialogs do not work. Any help would be much appreciated. Thanks
RaphaelR
hi Robert,
as described in the help topic, the transform method is an optional parameter(String), which you´ll need to specify.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000007m000000
for example:
in_FC = path to in_FC
out_FC = path to out_FC
install_dir = arcpy.GetInstallInfo()['InstallDir']
outCS = os.path.join(install_dir, r"Coordinate Systems\Projected Coordinate Systems\UTM\WGS 1984\Northern Hemisphere\WGS 1984 UTM Zone 33N.prj")
transform_method = "MGI_To_WGS_1984_3"
arcpy.Project_management(in_FC, out_FC, outCS, transform_method)
