I am trying to upload a File geodatabase, but cannot publish in Portal 10.4.1
4409
08-03-2016 02:59 AM
HugoBouckaert
Hi
I am uploading a File geodatabase using the new arcgis.gis API. Because my Portal is 10.4.1, I should be able to publish the contents of the file geodatabase as feature services. I can upload and publish a shape file, but with similar code, uploading a file geodatabase works, but publishing fails.
Here is the code for the uploading the file geodatabase:
from arcgis.gis import *
gis = GIS("http://<myportalserver>/arcgis","<username", "<password>")
data = "C:\\temp\\fgdbtest.zip" # File geodatabase zipped up
item_properties = {}
item_properties ["type"] = "fileGeodatabase"  # I need the type definition, otherwise add did not work
fgdbdata = gis.content.add(item_properties, data)# this works, the item is uploaded
fgdbdata.publish() # ERROR:
I get an error that Nonetype has no attribute publish(), so obviously fgdbdata is empty or None. Yet almost the same code does work when uploading a shape file.
Does anyone have an example where a File geodatabase is uploaded as a new item and then the feature classes within published as feature services?
Hugo
JayantaPoddar
Try using the type as "ZIP" or ".ZIP".
If that doesn't work, try doing the steps manually as mentioned in the following link "Publish the contents of a File Geodatabase".
https://doc.arcgis.com/en/arcgis-online/share-maps/publish-features.htm
Note: You can publish the following data types from an FGDB to a hosted feature layer
     i) Feature Classes (X and Y coordinates; M and Z coordinates will be dropped, if any)
     ii) Tables
     iii) Attachments
     iv) Relationship Classes
Think Location
RohitSingh2
Set the type as 'File Geodatabase', not 'fileGeodatabase':
item_properties['type'] = "File Geodatabase"
When publishing the item, specify a name without periods and spaces, eg:
fgdbdata.publish({'name' : 't3_Name_of_service'})
HugoBouckaert
Thanks a million, you saved my bacon, it works!
I spent hours on this so your reply is greatly appreciated!
Thanks again
Cheers
Hugo
