How to work with geodatabases?
7323
12
03-04-2015 06:38 AM
SaidAkif
Hi all
In my python code scripting, some time I used some function to do analysis on shapefile. Those function need to specify the .shp in the filename like arcpy.Rename_management(output+'.shp', filename). When I used files in geodatabase, my script crashed.
I am wondering how I can handle this problem?
I want just specify that my script loop over lot of files.
Thanks in advance
BlakeTerhune
Just copy and paste your code into the post as plain text; forget the syntax highlighting.
SaidAkif
import arcpy
import os
import sys
import tkMessageBox
from arcpy import env
mxd = arcpy.mapping.MapDocument("CURRENT")
df = arcpy.mapping.ListDataFrames(mxd,"Layers")[0]
# Set all the parameters
choice = arcpy.GetParameterAsText(0)
workspace = arcpy.GetParameterAsText(1)
fClass = arcpy.GetParameterAsText(2)
addFields = arcpy.GetParameterAsText(3)
reStruct = arcpy.GetParameterAsText(4)
addMiss = arcpy.GetParameterAsText(5)
delShp = arcpy.GetParameterAsText(6)
# Set fields parameters
namesFields =["SciName","CommName_E","CommName_F","Population","SpeciesID","SiteID","SiteName","CHApproach",\
       "CHMethod","Region","ProvTerr","LandTenure","UTMZone","Easting","Northing","Latitude","Longitude",\
       "Area_ha","Comments","DateEdited"]
typeF = ["STRING","STRING","STRING","STRING","SHORT","STRING","STRING","STRING","STRING","STRING","STRING",\
         "STRING","SHORT","DOUBLE","DOUBLE","DOUBLE","DOUBLE","DOUBLE","STRING","DATE"]
lenghF = [100,100,100,100,"",125,125,50,75,75,75,75,"","","","","","",250,""]
labelS=["Scientific","Common","Nom","Population","COSEWIC","Site ID","Site Name",\
        "Approach","Method","Region","Province","Tenure","UTM","Easting",\
        "Northing","Latitude","Longitude","Area","Comments","Date"]
# Set the workspace
env.workspace = workspace
# Verify the single feature class and the selected choice
if (choice == "false" and fClass == ""):
    arcpy.AddMessage("----------------------------------------------------------------")
    arcpy.AddMessage("Workspace/Single feature class check box is unselect.\n You have to select a single feature class or click to select the check box")
    sys.exit()
# Rename function
def rename_fields(table, out_table, new_name_by_old_name):
    existing_field_names = [field.name for field in arcpy.ListFields(table)]
    field_mappings = arcpy.FieldMappings()
    field_mappings.addTable(table)
    for old_field_name, new_field_name in new_name_by_old_name.iteritems():
        if old_field_name not in existing_field_names:
            message = "Field: {0} not in {1}".format(old_field_name, table)
            raise Exception(message)
        mapping_index = field_mappings.findFieldMapIndex(old_field_name)
        field_map = field_mappings.fieldMappings[mapping_index]
        output_field = field_map.outputField
        output_field.name = new_field_name
        output_field.aliasName = new_field_name
        field_map.outputField = output_field
        field_mappings.replaceFieldMap(mapping_index, field_map)
    # use merge with single input just to use new field_mappings
    arcpy.Merge_management(table, out_table, field_mappings)
    return out_table
# Reorder function
def reorder_fields(table, out_table, field_order, add_missing=addMiss):
    existing_fields = arcpy.ListFields(table)
    existing_field_names = [field.name for field in existing_fields]
    existing_mapping = arcpy.FieldMappings()
    existing_mapping.addTable(table)
    new_mapping = arcpy.FieldMappings()
    def add_mapping(field_name):
        mapping_index = existing_mapping.findFieldMapIndex(field_name)
        # required fields (OBJECTID, etc) will not be in existing mappings
        # they are added automatically
        if mapping_index != -1:
            field_map = existing_mapping.fieldMappings[mapping_index]
            new_mapping.addFieldMap(field_map)
    # add user fields from field_order
    for field_name in field_order:
        if field_name not in existing_field_names:
            raise Exception("Field: {0} not in {1}".format(field_name, table))
    # add missing fields at end
    if add_missing:
        missing_fields = [f for f in existing_field_names if f not in field_order]
        for field_name in missing_fields:
    arcpy.Merge_management(table, out_table, new_mapping)
    return out_table
# Processing
# Target the selected fields
namesA = []
names = []
namesA= addFields.split(";")
for i in range (0,len(namesA)):
    for j in range (0,len(labelS)):
        if labelS in namesA:
            names.append(namesFields)
arcpy.AddMessage("List of fields to add = ")
for i in range(0, len(names)):
    arcpy.AddMessage(names)
if choice == "true":
    listCH_fc = []
    listCH_fc = arcpy.ListFeatureClasses()
else:
    listCH_fc = []
    listCH_fc.append(fClass)
for fc in listCH_fc:
    # Add fields
    fieldList = arcpy.ListFields(fc)
    nameList = []
    nameListO = []
    new_name_by_old_name={}
    for lst in fieldList:
        nameList.append(lst.name.lower())
        nameListO.append(lst.name)
    for i in range (0,len(names)):
        if not names.lower() in nameList:
            arcpy.AddField_management(fc,names,typeF,"", "", lenghF, names, "NULLABLE")
        else:
            indexes = [k for k, l in enumerate(nameList) if names.lower() in l]
            old = nameListO[indexes[0]]
            new = names
            arcpy.AddMessage(old)
            arcpy.AddMessage(new)
            new_name_by_old_name.update({old:new})
    arcpy.AddMessage("New_name and old name for the fields to rename:")
    arcpy.AddMessage(new_name_by_old_name)
    output = str(fc).replace('.shp','')+"_AddRenameF"
    rename_fields(fc, output, new_name_by_old_name)
    if reStruct == "true":
        fieldListRE = arcpy.ListFields(output+".shp")
        nameListORE = []
        for lstRE in fieldListRE:
            nameListORE.append(lstRE.name)
        nameListORE_F = []
        for ii in range(0,len(namesFields)):
            for jj in range (0, len(nameListORE)):
                if nameListORE[jj] == namesFields[ii]:
                    nameListORE_F.append(nameListORE[jj])
        output_R = output.replace('.shp','')+"_RF_ReorderF"
        reorder_fields(output+".shp", output_R, nameListORE_F)
        # Delete existing feature class (fc) and rename generated feature class
        filename = fc
        arcpy.Delete_management(filename)
        if choice == "false":
            filename=os.path.basename(str(fc)).rstrip(os.path.splitext(str(fc))[1])
            filename = filename.replace('.shp','')
        else:
            filename = str(fc).replace('.shp','')
        arcpy.Rename_management(output_R+".shp", filename + ".shp")
        # add layer to mxd
        filename=os.path.basename(str(filename)).rstrip(os.path.splitext(str(filename))[1])
        if arcpy.Exists(filename):
        arcpy.MakeFeatureLayer_management(filename+".shp", filename.replace('.shp',''))
        layer = arcpy.mapping.Layer(filename.replace('.shp',''))
        layer.visible = False
        arcpy.mapping.AddLayer(df, layer, "BOTTOM")
    if (delShp == "true" and reStruct == "true"):
        filename=os.path.basename(str(output)).rstrip(os.path.splitext(str(output))[1])
        arcpy.Delete_management(filename + ".shp")
    else:
        # add layer to mxd
        arcpy.AddMessage(filename)
TedKowal
Honored Contributor
I believe Owain Catton mentioned that you are trying to append ".shp" to the name which is invalid for  a geodatabase.  .shp is reserved for Shape files....
So there may be a question on whether or not you are using Geodatabase layers or layers derived from shape files?
