How to use python to calculate some fields value?
1288
06-23-2013 03:35 AM
fenggao1
Now, i have a question about how to use python to calculate some fields value.Like fieldname1??fieldname2??fieldname3.When i got that value,how can i make fieldname4 = fieldname1??fieldname2??fieldname3??Thank you.
DanPatterson_Retired
Use the field calculator and set the parser to Python, then click on each field's name with * in between in order get the calculation you need
fenggao1
Thank you very much.This question has been solved.
