how to use portalpy with win-authenticated SSL
6212
03-30-2015 09:49 AM
SteveStearns
We have an enterprise Portal that uses SSL-only and does windows-authentication from your PC domain login.
I recently downloaded the 'portalpy' extension from ESRI and tried to run an example script, a simplified version shown below.
import sys
# bring in the portal python library
portalpyPath    = r'C:|Python27\portalpy-master'
sys.path.append(portalpyPath)
import portalpy
# Login to portal, collect all users
portalUrl           = "https://ourserver.enterprize.com:7443/arcgis/home"
portalAdminUser     = "PortalAdmin"
portalAdminPassword = "AdminMasterPW"
portal = portalpy.Portal(portalUrl, portalAdminUser, portalAdminPassword)
# Loop through the portal, printing stats
for user in portal.get_org_users():
    print user['username']
This in turn gets an SSL error shown below.
  File "c:\Python27\portalpy-master\portalpy.py", line 115, in __init__
referer, proxy_host, proxy_port)
  File "c:\Python27\portalpy-master\portalpy.py", line 1247, in __init__
self.login(username, password, expiration)
  File "c:\Python27\portalpy-master\portalpy.py", line 1262, in login
newtoken = self.generate_token(username, password, expiration)
  File "c:\Python27\portalpy-master\portalpy.py", line 1256, in generate_token
resp = self.post('generateToken', postdata, ssl=True)
  File "c:\Python27\portalpy-master\portalpy.py", line 1463, in post
resp = opener.open(url, data=encoded_postdata)
  File "C:\Python27\ArcGISx6410.2\lib\urllib2.py", line 404, in open
response = self._open(req, data)
  File "C:\Python27\ArcGISx6410.2\lib\urllib2.py", line 422, in _open
'_open', req)
  File "C:\Python27\ArcGISx6410.2\lib\urllib2.py", line 382, in _call_chain
result = func(*args)
  File "C:\Python27\ArcGISx6410.2\lib\urllib2.py", line 1222, in https_open
return self.do_open(httplib.HTTPSConnection, req)
  File "C:\Python27\ArcGISx6410.2\lib\urllib2.py", line 1184, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 1] _ssl.c:504: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure>
I've seen various posts on the net that talk about OpenSSL problems and hacks, but I'm betting somebody on this group has worked with portalpy in a secure domain before now.
What's the work-around here?  Do I need to import a different module and change an SSL default setting?
JulieBrown
VikramS
Did you get this working ? I am also facing the same issue
JulieBrown
We used the information in this article and go it working:
http://support.esri.com/en/downloads/patches-servicepacks/view/productid/207/metaid/2177
