How to use ApplySymbologyFromLayer in Python-script?
3148
10
10-26-2017 12:40 AM
ThomasKölbel
New Contributor II
ArcGIS Pro 1.4, 2D-Map
I'm trying to change the symbology of a featureclass  through a layerfile (.lyrx):
import arcpy
arcpy.MakeFeatureLayer_management("myFc", "myFc_lyr")
inputLayer = "myFc"
symbologyLayer = "myFc.lyrx"
symbologyFields = [["VALUE_FIELD", "StrKlasse", "StrKlasse"],["VALUE_FIELD", "Abschnitt_Ast", "Abschnitt_Ast"]]
arcpy.ApplySymbologyFromLayer_management (inputLayer, symbologyLayer, symbologyFields)
Running the commnds in the python-window, the symbology will be changed as expected, but in a python script from a toolbox nothing happens. The attributes in lyrx-file and the fc/layer match correctly.
Thanks for any solution.
DanPatterson_Retired
http://pro.arcgis.com/en/pro-app/tool-reference/data-management/apply-symbology-from-layer.htm
In both examples, not in immediate mode, the scripts set the arcpy.env variable (see examples 2 and 3)
Try adding that information since it is lacking your script
ThomasKölbel
New Contributor II
Thank's for your answer. I've tried:
import arcpy
from arcpy import env
env.workspace = r"C:\ArcGIS\Projects\MyProject6"
inputLayer = "myFc"
All sources are in the same Project folder.  The script runs and completes with no error, but nothing is changed.
I am not used to seeing script tool without a dialog that allows you to select layers etc http://pro.arcgis.com/en/pro-app/help/analysis/geoprocessing/basics/create-a-python-script-tool.htm
The need to refresh the map doesn't exist as an option as it did with ArcMap, so that can't be an issue.  That leaves something in the toolbox environment.  Try converting your hardcoded parameters into variables for selection
XanderBakker
Esri Esteemed Contributor
If the script runs as a standalone script, the arcpy.ApplySymbologyFromLayer_management  will probably have little effect if you don't:
  • apply it to a layer in a MXD, refresh the map and store the MXD
  • or save the layer as a layerfile with the applied symbology
ThomasKölbel
New Contributor II
There is no mxd in Pro.
same message as Xander... just called an *aprx
ThomasKölbel
New Contributor II
Converted the four Parameters inputLayer, symbologyLayer and ValueField1 and ValueField2 to selectable params in my script. No changes like before.
I've written some scripts before without dialogs - just running commands. They all worked well. So hardcoded params can be used.
WillArellano
I am having the same issue as the original poster but I am running ArcPro 2.6, python 3
My code to add symbology from a layer works great if I run it in a Notebook, but does not work when used in a script tool. When run in the script tool no errors are thrown, and a little lock icon shows up next to the input layer in the Contents window, so it looks like it is working, but the symbology is unchanged.
If I use the geoprocessing tool and run AddSymbologyFromLayer, it works perfectly so I know it isn't a bad .lyrx or other file issue.
Ideas?
RebeccaKRansom
I am also having the same issue in ArcGIS ArcPro 2.9, python 3.
I have a lyrx file and the ApplySymbologyFromLayer tool works from the python window and in a standalone script, but when I try to run it from a toolbox script it is not updating. Also, I am getting no errors.
