How to update existing Excel .xlsx file using Openpyxl?
12345
06-07-2021 07:25 PM
BriamR
I am trying to make this code work, the problem is that in the excel file the print (...) data is not written, I have tried to use ws.appened (...) but without results.
import arcpy
from openpyxl import Workbook
wb = Workbook("C:/Users/Hp/Desktop/ejemplo/VINCULACION_S.xlsx")
ws =  wb.active
rows = arcpy.SearchCursor("C:/Users/Hp/Desktop/ejemplo/VH_Dissolve.shp",
                          fields="COLOR; INTERNO_DE; CLASE_DEMA; COUNT_AREA; SUM_AREA; SUM_LENGTH",
                          sort_fields="COLOR 222; INTERNO_DE A")
# COLOR, INTERNO_DE, CLASE_DEMA, COUNT_AREA, SUM_AREA y SUM_LENGTH.
for row in rows:
    print("Color: {0}, Interno: {1}, Clase:{2}, ContarA: {3}, SumarA: {4}, SumarL: {5}".format(
        row.getValue("COLOR"),
        row.getValue("INTERNO_DE"),
        row.getValue("CLASE_DEMA"),
        row.getValue("COUNT_AREA"),
        row.getValue("SUM_AREA"),
        row.getValue("SUM_LENGTH")))
wb.save('VINCULACION_S.xlsx')
I have also tried to locate the results data in the excel file from cell B3: G3 onwards but I can't find it.
BriamR
I got this code as a solution to the post
import arcpy
import openpyxl as px
def main():
    wb = px.load_workbook(r"C:\Users\Hp\Desktop\Ejemplo\VINCULACION_S.xlsx")
    ws = wb['VINCULACION_SH_NUE']
    in_features = r"C:\Users\Hp\Desktop\Ejemplo\VH_Dissolve.shp"
    row_num = 3
    with arcpy.da.SearchCursor(
        in_features,
        ["COLOR", "INTERNO_DE", "CLASE_DEMA", "COUNT_AREA", "SUM_AREA", "SUM_LENGTH"],
    ) as cursor:
        for row in cursor:
            ws.cell(row=row_num, column=2).value = row[0]
            ws.cell(row=row_num, column=3).value = row[1]
            ws.cell(row=row_num, column=4).value = row[2]
            ws.cell(row=row_num, column=6).value = row[3]
            ws.cell(row=row_num, column=7).value = row[4]
            ws.cell(row=row_num, column=8).value = row[5]
            row_num += 1
    wb.save(r"C:\Users\Hp\Desktop\Ejemplo\VINCULACION_S.xlsx")
if __name__ == "__main__":
    main()
DanPatterson
MVP Esteemed Contributor
Use data access cursors
SearchCursor—ArcGIS Pro | Documentation
And try your field list as a list, not a concatenated string
... sort of retired...
BriamR
import arcpy
def main():
    row_num = 3
        in_features,
    ) as cursor:
        for row in cursor:
            row_num += 1
    main()
