how to slice a label field
4701
02-16-2011 03:56 PM
wilfredwaters
I have a field 'Name' where the first two letters of every string are 'ID'. Following 'ID' are between 1 and 2 characters, for example 'ID1' or 'ID11'. I want to create a label expression for arcGIS 10 that slices everything after ID. In python this is something like Name [2:] to return everything after the 2nd character. The label expression generator, however, only takes VBscript. Does anyone know what to do?
Wil
wilfredwaters
i fixed it by manually making a new field then field calculating it with !name![2:] (python was turned on as the parser. argGIS should allow a python parser in the expression generator
RussellHooper
In the "Label Expression" window, with Python selected as the Parser, type:
[Name].lstrip('ID']
This should remove ID from all of your labels.
R
