How to set scale range to show layer at all scales
2290
01-03-2020 10:54 AM
RickHawkins
I am trying to set the scale range under layer properties>general. I want to set the scale to "show layer at all scales" using python script.
What would be the correct way to set this?
Thanks
JoshuaBixby
MVP Esteemed Contributor
Set a Layer—ArcPy | ArcGIS Desktop maxThreshold and minThreshold to 0 to clear both, which will result in having the layer draw at all scales.
JoshuaBixby
RickHawkins
Thank you so much
JoshuaBixby
If someone's reply answers your question, please mark it correct to close out the question.  If there are multiple replies, either from one or multiple people, pick the reply that was most helpful in answering your question.
