How to read Multivalues from parameter into string Using Python
1414
08-05-2011 11:25 AM
MikeMacRae
I have set up a parameter with date type as "Date". I have also set the parameter to include multivalues so the user can enter various dates into a multivalue list. I want to pass the values into a list of strings or a table or something so that I can iterate through each one and read.
Basically, I have this:
import arcpy
Date1 = arcpy.GetParameterAsText(0)
arcpy.AddMessage(Date1)
When I add some dates to the value list, the AddMessage returns this:
08-26-2009;08-27-2009;08-29-2009
I want to split the values from the semicolons and store them so that I can use the values to enter into a text string later on in my script.
Mike
Mike
JasonScheirer
Esri Alum
Dates = arcpy.GetParameterAsText(0).split(";")
MikeMacRae
Jason, again you've offered a good solution.
Mike
