How to populate a field by the field name having the maximum value across the rows?
1980
07-08-2021 08:25 PM
badrinathkar
I have a point shapefile that contains five fields including the Id field. Now, I want to find the max value across the rows and populate another row with the field name having the maximum value. How to do this using python?
The table looks like this
IdX1X2X3X4MaxValue
1105151166
262305625
384222824
493278936
571333577
656546839
722567172
881524941
979293332
1037207351
DanPatterson
MVP Esteemed Contributor
conceptually
vals = [105, 15, 111, 66]
["X1", "X2", "X3", "X4"][vals.index(max(vals))]
'X3'
in practice
["X1", "X2", "X3", "X4"][vals.index(max(!X1!, !X2!, !X3!, !X4!))]
without actually checking.... obviously a field calculation into a string/text field using python parser
... sort of retired...
BlakeTerhune
Does it matter how ties are broken (if two or more fields have the same maximum value)?
badrinathkar
No.
DanPatterson
max takes the first
