How to output datasets to an open map/contents pane in ArcPro when running geoprocessing tool
7189
15
01-26-2021 03:13 AM
Darius
  • I made a python script which is finding min & max values within a specified buffer around specific location and pointing these locations on the map/raster.
  • This is now configured in a Toolbox as a geoprocessing tool for ArcGIS Pro with configurable parameters.
  • While running the tool, it is outputting the clipped raster, table (with min max values) and point feature class with min max values with coordinates to show min/max locations on the map.
How to add table/raster/feature class which are outputted by the tool directly to file geodatabase? Appreciate for any hints 🙂
  • I tired "Add output datasets to an open map" but without success:
  • I tried as well adding the extra code in the python script (did not output dataset to Contents pane)
arcpy.management.MakeFeatureLayer('Min_max_points', 'Min_max_points')
arcpy.AddMessage("Min&Max table added to Contents")
All these datasets are outputted to file gedatabase
but nothing is added to Contents pane
ArthurCallan
Did you ever find a solution for this? I am having the exact same issue. Running it as a script tool does not add the data to the Contents. However, running my script in ArcPro's Python Window does output data to Contents Pane.
DanielJager
If you're still working on this, I have found that this works for me.
arcpy.MakeFeatureLayer_management("SurveyArea_" + date, "Selection_LayerName")[0]
arcpy.SaveToLayerFile_management("Selection_LayerName", "Selection_LayerName.lyrx")
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.listMaps("Map")[0]
selection = arcpy.mp.LayerFile("Selection_LayerName.lyrx")
m.addLayer(selection, "TOP")[0]
DanielJager
Any luck? Are you running 2.8?  I am having the same issues, I've tried all sorts of things, running arcpy.mp but that seems like it mostly used in python window not script tool.
PICAR40
I do have the same problem and the only solution I found is to use a LayerFile to display the dataset, but it is not very fantastic to proceed like this because the .lyrx must exist. But it is a fact that the Content result of the execution of a geoprocessing tool in the Python consol is not the same as if the geoprocessing tool is executed ftom a Python script. Shame on ESRI to not explain this in the documentation.
radius = arcpy.GetParameterAsText(1)
pt = point_geometry.projectAs(spatial_reference_mtm7,"NAD_1983_CSRS_To_WGS_1984_2")
pointGeometryList = []
pointGeometryList.append(pt)
arcpy.CopyFeatures_management(pointGeometryList,r"memory\Point_outil42")
#add a cercle (polygon)
arcpy.analysis.Buffer(r"memory\Point_outil42", r"memory\Outil42", radius, "FULL", "ROUND", "NONE", None, "PLANAR")
#adding the contents of the "memory\Outil42" to the Content using a LayerFile
insertLyr = arcpy.mp.LayerFile("Outil42mem.lyrx")
carte.addLayer(insertLyr)
PICAR40
Also this solution to use a LayerFile creates a problem with exportToPDF() because ArcGIS Pro 2.8.1 freeze after creating the PDF file.
StefanBrandt
This topic is already over a year old, but I likewise stumbled upon the same issue.
Has there been a more recent solution to this problem? I'm using a python script in combination with a task element, but since outputs aren't added to the map, some steps in the task don't work properly.
