So I hopefully have a really simple question here. I am writing a codeblock for the CalculateField_management function but due to the length of my codeblock, and the fact that I will have to repeatedly edit it in the future, I want to put the codeblock into another py text file and then open it within a main script and pass it in as a string for CalculateField_management to interpret.
This sounds very simple, but when trying to google it, I only ever get help on modules and arguments. The problem with creating a module is that I cannot have my codeblock function defined outside of CalculateField, so the input definition needs to go into the codeblock as a string. This is what I tried so far but it does not know that f is suppose to reference my opened file.
File "<string>", line 3, in <module> NameError: name 'f' is not defined Failed to execute (CalculateField).
import arcpy
inTable = "Zarza data"
fieldName = "DipDir"
expression = "Strike( !Shape!, !FID! )"
codeblock ="""
open("D:/Alex/someplace/ZarzaModule.py",'r')
val = f.read()
print(val)
arcpy.CalculateField_management(inTable, fieldName, expression, "PYTHON_9.3", codeblock)
I might also need to operate the code outside of my codeblock and have:
codeblock = str(val)
But I need to fix referencing my opened file first.
