How to make this extraction process faster
1753
6
03-08-2012 02:07 PM
zhengniu1
I have a point shapefile wihch has 527k data points.
1st step: I am trying to create a 4 meters buffer at each points to find its neighbours and corresponding information (such as X, Y, direction) within the buffer.
2nd step: To identify the points which fall in the overlapping area of two or more buffer, and assign them to their real buffer by comparing distances to each buffer's center
3rd step:  Using all points (including the focal point) within the buffer to calculate average position (avg_X and avg_Y) and avg_Direction.
4th step: change the buffer point's x, y and direction to the avg_X, avg_Y, and avg_Direction.
Following code is for the 1st step
import arcpy, math
arcpy.env.workspace = r'C:\TempArcGISCalculate\TempFile\TestforReadingFile'
arcpy.env.overwriteOutput=True
ptfc = 'Section01_SplitedTrips.shp'
arcpy.MakeFeatureLayer_management(ptfc,'section01pts')
arcpy.Buffer_analysis(ptfc,'in_memory/Section01Buffer','4 meters')
arcpy.MakeFeatureLayer_management('in_memory/Section01Buffer','S1buffer')
#Cut out points inside each buffer
rows = arcpy.SearchCursor('in_memory/Section01Buffer')
row = rows.next()
count = 1
try:
    while row:
        selPoly =arcpy.SelectLayerByAttribute_management('S1buffer',"NEW_SELECTION","\"FID\"="+str(row.FID))
        selPts = arcpy.SelectLayerByLocation_management('section01pts',"WITHIN",selPoly, 0, "NEW_SELECTION")
        curs = arcpy.SearchCursor(selPts)
        for cur in curs:
            print count, cur.getValue('LON_X')," ", cur.getValue('LAT_Y')," ", cur.getValue('InitialBea')," ", cur.getValue('Trace')," ", row.getValue('LON_X'), " ", row.getValue('LAT_Y'), " ", row.getValue('Trace')
        del cur,curs
        row =rows.next()
        count = count + 1
   del row, rows
except Exception, e:
    #If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    print "line %i" % tb.tb_lineno
    print e.message
Q1: Is it possible to make this process faster? it is ok for dataset which has row less than 1000, but takes longer as more date involved
Q2: When I add " print arcpy.AddMessage("Elapsed time: " + str(time.clock() - beginTime))" before "del row, rows", It always tells below. This command used to be ok for my previous script.
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 312, in RunScript
    exec codeObject in __main__.__dict__
  File "C:\TempArcGISCalculate\PythonScript\SelectbyLocation.py", line 31, in <module>
NameError: name 'time' is not defined
ChrisSnyder
Honored Contributor
Anything is possible...
Can you give a narative description of what this code is doing? Looks like it is attempting to define some sort of 'spatial association' - like identifying the points within the buffer of a polygon.
Maybe a conventional overlay tool would better serve this purpose... For example, Intersect (Intersect tool) your polygons buffers with your points and cursor through that output.
ChrisSnyder
Honored Contributor
And you need to import the time module to get time.clock() to work
import time
zhengniu1
Sorry for making you confuse. I restate my problem again.
ChrisSnyder
Honored Contributor
Thanks for the narative.
So I think you can:
1. Buffer your points
2. Run an Identity (or Intersect) tool on your points and buffer polygon - This will "tag" each point with what point buffer it is within - be carefull because you will end up with duplicate points where the buffer polygons overlap!!!
3. In a cursor (maybe helpfull to use a Python dictionary to sort out some of the realtionships) - use the Intersect/Identity tabular information (x/y/point_id/buffer_id) to analyze the realtionships.
Run a small sample area of your point and point buffers through the Identity or Intersect tools to see what can be done with the output table info.
A recursive SelectByLocation will be extreemly slow compared with the convetional Intersect or Identity tools.
zhengniu1
So I think you can:
Here is my code using Intersect_analysis instead of SelectLayByLocation
import arcpy, time
t0=time.clock()
ptCurs=arcpy.SearchCursor('S1buffer')
ptcur = ptCurs.next()
count = 1
while ptcur:
    selPoly=arcpy.SelectLayerByAttribute_management('S1buffer',"NEW_SELECTION","\"FID\"="+str(ptcur.FID))
    themeList=['S1buffer',ptfc]
    arcpy.Intersect_analysis(themeList,'in_memory/points_within_buffers')
    bufPts = 'in_memory/points_within_buffers'
    PtCount = arcpy.GetCount_management(bufPts)
    curs = arcpy.SearchCursor(bufPts)
    print PtCount
    for cur in curs:
    del cur,curs
    count = count + 1
    if count>10:
        break
del ptcur, ptCurs
print "Elapsed time: " , time.clock() - t0
I use 10 sample data points for both script. the results are same. However, the Intersect takes 39.5106703156 secs; SelectLayByLocation takes 9.16266229449 sec
Could you please have a look at the Intersect one, please?
ChrisSnyder
Honored Contributor
No need to loop - just this:
import arcpy, time
t0=time.clock()
bufferFC = 'in_memory/Section01Buffer'
arcpy.Buffer_analysis(ptfc, bufferFC,'4 meters')
identityFC = r"in_memory\identity"
arcpy.Identity_analysis(ptfc, bufferFC, identityFC, "ALL", "", "")
Then I think all the info you should need is it the attribute table of  identityFC
Maybe add/populate an X andY field. Beware that you will now have poiuts that will overlap n times in areas that have n overlapping buffer polygons.
Then use a searchcursor and a python dictionary. You can key the dictionary by (x,y) coordinate pairs. Might have to build a few different dictionaries to keep track of everything.
