how to make long file name shorter
5801
07-11-2012 04:28 PM
ElaineKuo
System: ArcGIS 9.3
Problem:
I have five shapefiles with long names:
A8923_Dis_shp.shp, A4592_Dis_shp.shp, A9820_Dis_shp.shp, A1276_Dis_shp.shp, A3726_Dis_shp.shp
I want to make their names shorter, such as
A8923.shp, A4592.shp, A9820.shp, A1276.shp, A3726.shp
Please kindly advise python code to carry out the task.
Thank you
K_Clark
Please kindly advise the function of
1. short = shapefile[:score]
2. %s.shp
Helenak, I'm glad you found the answer to your original question.
To answer the questions you just posted, kindly refer to the following sources:
Slicing in Python
String formatting in Python
Google is your friend.
K_Clark
System: ArcGIS 9.3
Hi Helenak,
I got this idea from gis.stackexchange and it works in ArcGIS 10 (I think arcpy uses the same logic as the arcgisscripting module).  If the subtext you want to change in the file name is dynamic, you might have to be more creative and use the re module.
Make sure all your shapefiles are in one folder and that an instance of the ArcMap document referring to those shapefiles (or ArcCatalog) isn't open.
import os
import arcpy
from arcpy import env
# directory containing shapefiles to be renamed
shapefile_dir = path = r'C:\ChangeShapefileNames\Shapefiles'
env.workspace = shapefile_dir
shapefileList = arcpy.ListFeatureClasses()
for shapefile in shapefileList:
  # get the shapefile name and file extension
  fileName,fileExtension = os.path.splitext(shapefile)
  # replace the strings you want to
  fileName = fileName.replace("_Dis_shp","")
  fileName = fileName + fileExtension
  # rename the files
  arcpy.Rename_management(shapefile, fileName)
gis.stackexchange.com is another great place to find the code bits you might need in the future.
I hope this helps.
RDHarles
Another option is "slicing":
import os
files = filter(os.path.isfile, os.listdir(''))
for file in files:
    # Split on the extension.
    split = file.split(".")
    # Get the first 5 characters in the file name
    name = split[0][:5]
    # Extension
    ext = split[1]
    print "Renaming "+file+" to "+name+"."+ext
    os.rename(file, name+"."+ext)
markdenil
even simpler: find the first underscore, and use everything before it.
tack on a ".shp"
copy to the new name
delete the old one (optional)
import arcpy
arcpy.env.workspace = shapefile_dir
    score = shapefile.find("_")
    arcpy.Copy_management(shapefile, "%s.shp" % short)
    arcpy.Delete_management(shapefile)
It is always good practice to use Arc for copying and changing names.
Shapefiles are pretty tolerant things... but good practice is good practice.
ElaineKuo
Thanks for the response.
2. %s.shp
import arcpy
K_Clark
2. %s.shp
Slicing in Python
