How to import a python toolbox?
22906
15
11-01-2013 06:54 AM
ionarawilson1
Can anybody tell me how to import a python toolbox and access the parameter of a tool inside the toolbox?
I have started importing the toolbox using the ImportToolbox function but I am not sure if this is correct:
    def onSelChange(self, selection):          ptoolbox = arcpy.ImportToolbox("D:/ArcGISData/SARS/Python_10April2013/Toolbox.pyt")
RhettZufelt
MVP Notable Contributor
Nowhere in the documentation for ImportToolbox does it say to use arcpy.alias.toolname().  It says to use arcpy.toolname_alias().  Your syntax works, the syntax in the documentation does not, which is what led me here.  Thanks for the tip, however you discovered it.
That explains it.  I had to make the alias and the name identical to get it to work.  Next time, I'll try it backwards from the documentation.
R_
AndrewMoffitt
I'd like to add that the toolbox name cannot contain spaces, so far as I can tell.
ShaunWalbridge
It works fine with spaces, if you're running into issues, post a code snippet and we can take a look. Here's an example of an import which works fine on my end:
arcpy.ImportToolbox(r'z:\pyt with spaces\more spaces.pyt')‍‍
# <module 'touche'>
AndrewMoffitt
For me, it was a non-python toolbox that caused the spacing issue. (I think. Now I'm second-guessing what I did to fix it).
ShaunWalbridge
OK, if you see the same behavior again, post it to GeoNet and we can see what's going on.
Cheers, Shaun
ionarawilson1
Thanks Jason
