How to import a Python script into ArcGIS
1969
06-20-2013 06:03 PM
BrittanyGale
Hello!
I created a python script tool that is going to be distributed online, and I want it to be able to be called from the ArcMap/Catalog python window (without having to include the function). If I drag the tool into the python window, "arcpy.ClipTIF(" appears, but when I try to execute the line of code with all of the appropriate attributes, I get this error:
Runtime error <type 'exceptions.AttributeError'>: 'module' object has no attribute 'ClipTIF'
FYI - "ClipTIF" is the name of my script tool and "clipTIF" is the name of my script's function. Neither work in the aforementioned line of code.
Question: How do I call the function from my python script tool in the ArcGIS python window?
Thank you in advance!
Brittany
JasonScheirer
Occasional Contributor III
You'll need to call arcpy.ImportToolbox(r"c:\path\to\toolbox.tbx") before calling the tool.
JasonScheirer
BrittanyGale
Thank you so much!
