How to get the attribute table value of a particular field where the field values are domain assigned values using arcpy
2381
6
05-01-2023 05:18 AM
kumarprince8071
This is the attribute table values of two fields but the values inside the fields are domain coded description values by using search cursor i am getting only the code not the values need help or suggestions for that.
Tags (3)
by Anonymous User
Not applicable
Use the list domains and find it for your featurclass:
domains = arcpy.da.ListDomains("C:/Boston/Boston.gdb")
for domain in domains:
    print(f"Domain name: {domain.name}")
    if domain.domainType == "CodedValue":
        coded_values = domain.codedValues
        for val, desc in coded_values.items():
            print(f"{val} : {desc}")
kumarprince8071
I have tried this way but i am getting all the domain coded values for that but i need only the field values like shown in the image. Kindly give me some suggestions on that please.
by Anonymous User
Not applicable
Filter on the field?
fc = r'path to your fc'
field = 'Field you want'
target_field = [f for f in arcpy.ListFields(fc) if field == f.name]
if target_field[0].domain:
    field_domain = [d for d in arcpy.da.ListDomains(arcpy.Describe(fc).path) if d.name == target_field[0].domain][0]
    for k,v in field_domain.codedValues.items():
        print(f'domain key: {k}  domain value: {v}')
kumarprince8071
File "D:\ARCPY\ArcPy_New\feature_exists.py", line 182, in <module>
IndexError: list index out of range
Getting this error
Attaching the code also
Here one more information is that ASSETGROUP field is a subtype field.
by Anonymous User
Not applicable
Instead of sending a list of fields, send a single field.
kumarprince8071
Yes, i tried it also but i'm not getting any result also not getting any error.
