How to get symbology and data source with python?
4888
6
02-06-2011 02:49 PM
RyanChan
I am wondering if it is possible for python to return the symbology and the data source information of a existing layer file? I search through gp.describe but there are no properties and methods that return symbology and data source. I simply want the value field of the symbology and the shapefile data source to be printed on the interactive window. Can anyone help?
BradPosthumus
Assuming when you say layer file it means the ".lyr" type, if you have comtypes installed you can use the code below. I simplified it from existing code I had lying around so you'll need to add error-checking at some point.
http://sourceforge.net/projects/comtypes/
def openLayerFile(strLayerFile):
    objLayerFile = comtypes.client.CreateObject(esriCarto.LayerFile, interface=esriCarto.ILayerFile)
    objLayerFile.Open(strLayerFile)
    return objLayerFile
def getValueField(objLayer):
    objFeatureLayer = objLayer.QueryInterface(esriCarto.IFeatureLayer)
    objGeoFeatureLayer = objLayer.QueryInterface(esriCarto.IGeoFeatureLayer)
    objFeatureRenderer = objGeoFeatureLayer.Renderer
    try:
        objRenderer = objFeatureRenderer.QueryInterface(esriCarto.IUniqueValueRenderer)
        return objRenderer.Field(0)
    except:
        try:
            objRenderer = objFeatureRenderer.QueryInterface(esriCarto.IClassBreaksRenderer)
        except:
            return ""
def getDataSource(objLayer):
    objDataLayer = objFeatureLayer.QueryInterface(esriCarto.IDataLayer)
    objDatasetName = objDataLayer.DataSourceName.QueryInterface(esriGeoDatabase.IDatasetName)
    objWorkspaceName = objDatasetName.WorkspaceName
    strDataSource = os.path.join(objWorkspaceName.PathName, objDatasetName.Name)
    return strDataSource
import comtypes.client
import os
esriCarto = comtypes.client.GetModule(r'C:\Program Files\ArcGIS\com\esriCarto.olb')
esriGeoDatabase = comtypes.client.GetModule(r'C:\Program Files\ArcGIS\com\esriGeoDatabase.olb')
strLayerFile = r"C:\Temp\test.lyr"
objLayerFile = openLayerFile(strLayerFile)
objLayer = objLayerFile.Layer
print getValueField(objLayer)
print getDataSource(objLayer)
del objLayer
del objLayerFile
NiklasNorrthon
In ArcGIS 9.x no.
In ArcGIS 10 you can get the datasource (look up "arcpy.mapping"), but not the symbology .
There are workarounds using the win32com.client module to access ArcObject's com interface directly, but that will make your scripts complicated, and probably not worth the effert, since you can do the same thing easier in C# or VB.
BradPosthumus
    return objLayerFile
    try:
    except:
        try:
        except:
            return ""
import os
del objLayer
del objLayerFile
RyanChan
    return objLayerFile
    try:
    except:
        try:
        except:
            return ""
import os
del objLayer
del objLayerFile
Thank you so much for your help. This works well with my layer files with single layer.
But I am greedy to know if its possible to read group layer files? It seems that errors occur when opening the group layer files.
BradPosthumus
Good point about the layerfiles containing a group of layers. I've added a function that allows it to also extract all layers if it's a group layer. It's recursive so it should work with nested group layers within a group layer.
Note that it's the ICompositeLayer interface, not IGroupLayer, that allows you to extract individual layers from a group layer. IGroupLayer simply accesses the general layer properties of the group.
    return objLayerFile
def getLayers(objLayer):
    """ Returns a list of layers from a layer file"""
    colLayerList = []
    try:
        objCompositeLayer = objLayer.QueryInterface(esriCarto.ICompositeLayer)
        for i in range(objCompositeLayer.Count):
            objCurrentLayer  = objCompositeLayer.Layer(i)
            try:
                objNestedCompositeLayer = objCurrentLayer.QueryInterface(esriCarto.ICompositeLayer)
                colLayersInGroup = getLayers(objCurrentLayer)
                colLayerList += colLayersInGroup
            except:
                colLayerList.append(objCurrentLayer)
    except:
        colLayerList.append(objLayer)
    return colLayerList
    try:
    except:
        try:
        except:
            return ""
import os
strLayerFile = r"C:\Temp\testGroup.lyr"
colLayers = getLayers(objLayerFile.Layer)
for objLayer in colLayers:
    print objLayer.Name
del objLayer
del objLayerFile
RyanChan
Thank you so much for your help Brad. This is so amazing. I really appreciate your help.
George_ChandeepCorea
Cheers,
Going along with what's been asked and commented on here - In an active Arc Map session - I want to change the symbology of a layer which is repeated multiple times in an mxd. Can I do this?
The basic code I have for getting the layers is below. This is running within ArcMap (not as a .py script)
myMXD = arcpy.mapping.MapDocument("Current")
lstDataFrames=arcpy.mapping.ListDataFrames(myMXD)
lstLayers=arcpy.mapping.ListLayers(myMXD)
hazardLayer=arcpy.mapping.ListLayers(myMXD,'*Haz*')
allFrames=arcpy.mapping.ListDataFrames(myMXD)
for dataFrame in allFrames:
...  myMXD.activeView=dataFrame
...  for mapLayer in hazardLayer:
     ...  mapLayer.visible=False
This just changes the visibility to off...can I change the color for example to some RGB value?
