how to execute an python arcsript
3580
8
07-11-2012 04:16 PM
ElaineKuo
System: ArcGIS 9.3
Problem
I want to use a code to split rows using a script downloaded from arcscript. (attached)
However, an error message showed that
"AttributeError: Object: Tool or environment <SplitByAttribute> not found"
Please kindly advise modification on the following code and thank you.
##Script Name: split rows ##Description: using  ##Created By: Elaine Kuo ##Date: 12/07/2012   #Import standard library modules import arcgisscripting import os  #Create the Geoprocessor object gp = arcgisscripting.create(9.3)   #Set the workspace. gp.Workspace= "H:/temp/test"   #Set the workspace. List all of the feature classes in the dataset outWorkspace= "H:/temp"  # Add a toolbox with a model to the geoprocessor and set the workspace gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolBox/Toolboxes/Split rows.tbx")   #Get a list of the featureclasses in the input folder fcs = gp.ListFeatureClasses()  # Loop through every item in the list that was just generated for fc in fcs:      # Break out the name, no path or extension, using the describe object.     desc = gp.describe(fc)     featureName = desc.name            #Validate the new feature class name for the output workspace.     OutFeatureClass = outWorkspace + os.sep + gp.ValidateTableName(fc,outWorkspace)      #get file name     fcName, fcExt = os.path.splitext(fc)       #build field name     fieldName = fcName      #### Execute Script Tool ####     gp.SplitByAttribute(fc, fieldName, outWorkspace, fieldName)     gp.AddMessage(gp.GetMessages()) print gp.GetMessages()
MarcinGasior
The error sugests that the toolbox you added
does not contain SplitByAttribute tool.
You can access this toolbox and tool in any location on your computer like:
gp.AddToolbox(r"C:\Temp\AdditionalAnalysis\Additional Analysis - Generic Tools.tbx")
The Script folder has to be in the same parent folder as .tbx toolbox.
Moreover, you can add toolbox alias (which is analysis2 in this case) to tool name:
gp.SplitByAttribute_analysis2(...)
MarcinGasior
ElaineKuo
Thanks for the response.
However, the location of the python tool is wrong and the code based on your modification did not work.
(The tool works well using arcGIS Desktop).
Please kindly advise how to make the source location of the python code correct.
Thank you.
(not File "H:\python_p\python_code\split_row_0717.py", should be File "C:\Program Files\ArcGIS\ArcToolbox\Scripts\SplitFC.py")
(I changed the source location using ArcGIS Desktop and ArcCatalog but did not work.)
The error message is as followed:
  File "C:\Python25\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 310, in RunScript
    exec codeObject in __main__.__dict__
  File "H:\python_p\python_code\split_row_0717.py", line 46, in <module>
    gp.SplitByAttribute_Analysis2(fc, fieldName, outWorkspace, fieldName)
AttributeError: Object: Tool or environment <SplitByAttribute_Analysis2> not found
MarcinGasior
Unzip the AdditionaAnalysis.zip to some folder.
Don't touch any files in unzipped folder.
Then just reference whole toolbox with tool of interest.
For location like in this image:
[ATTACH=CONFIG]16155[/ATTACH]
the reference path will be:
ElaineKuo
Thank you for the response.
I modified the code and copied the unzipped folder to the ArcToolbox folder.
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolBox/Toolboxes/AdditionalAnalysis/Additional Analysis - Generic Tools.tbx")
However, the same error still existed.
MarcinGasior
That's strange.
When you browse in ArcCatalog to this toolbox, do you see something like this:
[ATTACH=CONFIG]16182[/ATTACH]
Can you run SplitByAttribute tool (which alias is Split Feature Class By Attribute) from ArcCatalog?
ElaineKuo
Yes, the tool exists as the same of your picture.
Also, it works in ArcCatalog.
Thank you again.
ElaineKuo
System: 9.3
Windows: vista
Problem: I am using the following code to execute a tool to split row in the shapefile in attached test1.
It ran smoothly without errors but no outcome appeared.
The tool is also attached as AdditionAnalysis.
Please kindly advise any improvement and thank you in advance.
Elaine
##Date: 23/09/2012
import os
#Set the workspace.
gp.Workspace= "H:\temp\test1"
outWorkspace= "H:\temp"
gp.AddToolbox("C:\TEMP\AdditionalAnalysis\Additional Analysis - Generic Tools.tbx")
for fc in fcs:
    #get file name
    #build field name
    fieldName = fcName
ElaineKuo
Finally, I made my own code.
##Description: to split featureclasses based on attributes
##Date: 24/09/2012
import os
#Set the workspace.
outWorkspace= "H:/temp/test"
for fc in fcs:
    #   Get a list of the fields in the featureclass
    fields = gp.listFields(fc, "C*", "String")
#Select S
    for field in fields:
        gp.toolbox = "Data Management"
        gp.addMessage(type(field))
        # Select records (C*, i.e. C7658)
        # Make temporary featureclasses
        query = "\"%s\" = 'S'" % field.Name
        gp.select_analysis(fc,("outputS.shp"),query)
        #get file name
        # replace the strings you want to
        fcName = fcName.replace("_Dissolve","S")
        fcName = fcName + fcExt
        gp.rename_management("outputS.shp", fcName)
        gp.delete(fc)
        #get file name
        #fcName, fcExt = os.path.splitext(fc)
        #fcName = fcName.replace("_Dissolve"," ")
        #fcName = fcName + fcExt
        #gp.rename_management(fc, fcName)
        # clear memory of temporary shapefiles
        #gp.delete("outputS.shp")
