How to execute a SQL Server stored procedure with ArcPy
3040
01-02-2019 08:11 AM
JoseSanchez
Hello everyone,
I need to execute a Ms SQL Server stored procedure using Arcpy.  Any source code samples that will hep me.
Thanks
JoshuaBixby
MVP Esteemed Contributor
ArcSDESQLExecute—ArcPy classes | ArcGIS Desktop may work, it depends on a couple of factors.
Why do you have to execute the stored procedure in "ArcPy?"  Why not just connect to it using a Python wrapper for SQL Server?
JoshuaBixby
JoseSanchez
I was looking for an option to run a Ms SQL Update statement because updating records using  arcpy.da.UpdateCursor  is too slow.
The first option was to add the SQL code in a stored procedure and run the stored procedure.
The second option, I just copy/pasted the code sample (http://pro.arcgis.com/en/pro-app/arcpy/classes/arcsdesqlexecute.htm) , added an Update SQL Statement to variable "sql_statement" , ran the code and it worked.
sql_statement = " UPDATE [owner].[Property] " \
"SET [FOLIO] = APP.TCIS_GIS.FOLIO " \
sql_statement_list = sql_statement.split(";")
egdb_return = egdb_conn.execute(sql)
Thanks
JoshuaBixby
Glad you could get something working.  Just a note of caution, ArcSDESQLExecute doesn't recognize versions, so you will be making updates to base tables unless your SQL is using versioned views.
JoseSanchez
In this case layers are not versioned, so ArcSDESQLExecute runs fine.
