How to Delete NULL Records
2717
8
04-07-2014 03:20 AM
H_A_D_Padmasiri
Dear Sir
I want to update "CNT_PT_ID" field & delete the NULL records ("CNT_PT_ID" is NULL). I wrote a python script.When it runs "CNT_PT_ID" is update correctly. But "CNT_PT_ID" = "Null" records not deleted. No error message display. Can you give me a help to correct it.
Thanks
Padmasiri
WilliamCraft
Try changing CNT_PT_ID" = "Null" to be "CNT_PT_ID" IS NULL instead.  Does that work?
H_A_D_Padmasiri
No it does not work it gives following error
  File "J:\Gampaha\Scripts\Script1.py", line 109, in <module>
    if row.CNT_PT_ID is NULL:
NameError: name 'NULL' is not defined
Failed to execute (LISTool1.0).
Thanks
benberman
It should look something like this:
cur = arcpy.UpdateCursor("CNT_Anno")
for row in cur:
        val1 = row.getValue("Some attribute field")
        if val1.isdigit():
                if int(val1) >= 9000:
                        row.setValue("CNT_PT_ID", int(val1))
                        cur.updateRow(row)
        if row.isNull("CNT_PT_ID")==True:
                cur.deleteRow(row)
del cur
del row
you may also be able to get away with deleting the isdigit() line.
Zeke
Honored Contributor
Python also often uses None instead of Null.
MathewCoyle
Honored Contributor
Give this a try.
layer = r'CNT_Anno'
cur = arcpy.da.UpdateCursor(layer, ['TextString', 'CNT_PT_ID'])
for row in cur:
    if row[0]:
        try:
            if int(row[0]) >= 9000:
                row[1] = int(row[0])
                cur.updateRow(row)
        except:
            pass
    if row[1] is None:
        cur.deleteRow()
H_A_D_Padmasiri
for row in cur:
        if val1.isdigit():
                        cur.updateRow(row)
                cur.deleteRow(row)
del cur
del row
Dear FLBB
It gives me Following Error
    if row.isNULL("CNT_PT_ID")==True:
  File "c:\program files\arcgis\desktop10.1\arcpy\arcpy\arcobjects\_base.py", line 28, in __getattr__
    raise AttributeError("%s" % attr)
AttributeError: isNULL
Thanks
benberman
Dear FLBB
Thanks
You typed "isNULL". You need to be typing "isNull". Case sensitivity very important in python.
AhmedEl-Sisi
This approach should work for you
if not row.CNT_PT_ID :
        cur.deleteRow(row)
