how to delete multiple mdb or gdb empty feature class.
2490
6
04-03-2018 06:36 AM
santhoshp
Dear Friends,
Kindly find the attached multiple mdb's. how to delete multiple mdb or gdb empty features class.any code available please help me.
Thanks
Santhosh
JamesCrandall
http://pro.arcgis.com/en/pro-app/arcpy/functions/listfeatureclasses.htm
arcpy.env.workspace = <workspace>
fcs = arcpy.ListFeatureClasses('*')
for fc in fcs:
    test = int(arcpy.GetCount_management(fc).getOutput(0))
    print 'Feature Count: {}'.format(test)
    if test > 0:
        print 'Deleting Feature Class: {}'.format(fc)
        arcpy.Delete_management(fc)
MitchHolley1
To add onto the concepts covered by @James, the following will take an input directory and loop over the gdbs and FCs for each one.
import arcpy
import os
inputDir = r'path\to\directory\that\houses\geodatabases'
ext = ['.mdb','.gdb']
gdbs = [x for x in os.listdir(inputDir) if x[-4:] in ext]
for g in gdbs:
    fullpath = os.path.join(inputDir, g)
    arcpy.env.workspace = fullpath
    for fc in arcpy.ListFeatureClasses():
        rowCount = arcpy.GetCount_management(fc)[0]
        if rowCount == '0':
            print "Deleting empty FC: {0}".format(os.path.join(g,fc))
            arcpy.Delete_management(os.path.join(fullpath,fc))
        else:
            print "{0} contains {1} records".format(os.path.join(g,fc), rowCount)
santhoshp
Hi Dear,
attached below snapshot can you give the solution for attached image.Delete multiple mdb empty feature class one time all mdb.
delete Multiple mdb or gdb empty feature class one time
Thanks
Santhosh
RandyBurton
You are using filename in the listing of extensions.  Just use the extension:
If the file ends in either of these extensions, then the filename will be found.  Also, you need to set the inputDir to the correct value.
MitchHolley1
Change the inputDir path to the directory that houses your geodatabases...
