How to Delete a text element (text box) in an mxd?
1234
06-09-2011 09:09 AM
MikeMacRae
I am creating a program to run through a number of mxd's to change some text elements for final delivery to my client. In the process, I want to delete a text element that says "DRAFT" in each .mxd when the program runs.
for textElement in arcpy.mapping.ListLayoutElements(mxd2, "TEXT_ELEMENT"):
    if textElement.text == "DRAFT":
        del textElement
    else:
        print "No DRAFT"
I tried del textElement and textElement.delete, neither seem to work.
I also tried setting the text box to nothing (ie textElement.text = "") but I need to actually get rid of the text box.
Thanks for any help,
Mike
MathewCoyle
Honored Contributor
FYI
http://forums.arcgis.com/threads/26979-Deleting-Layout-Elements-with-arcpy.mapping
Closest thing you can do is set height/width to zero.
MikeMacRae
Thanks for the response Matthew. Looks like I am setting it to " "
Cheers,
Mike
